Old 11-23-2016   #1
billschroeder5842
billschroeder5842's Avatar
Default Cleaning engine parts
I'm a bit of a neat freak when it comes to the engine bay.
Has anyone found a method/chemical/spray etc that works well on the engine itself? I have small "stains" that are here and there from what appears to be oil.
I've tried Simple Green, Purple power and a few other bio degradable products.
The only thing that seems to work is Acetone. I'll be happy to use it, but when I rub it on the covers or manifold "silver" comes off on the rag, so I worry about damage.
Anyone had success with something else?
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 11-24-2016   #2
BigJohn
BigJohn's Avatar
Default Re: Cleaning engine parts
My fixed for The stains was having the engine powder coated!
Old 11-24-2016   #3
32valvesftw
The paint on the LT5 is sensitive to chemicals, so I would be careful about their use. What I had some luck with was 0000 Steel Wool with a cleaner wax at the sametime. Go slow with a light touch. I got many, not all, of the stains off my engine that way.
Old 11-24-2016   #4
Most the time cleaning even with wax will turn it a darker gray hiding the stains. I just repainted mine.
http://www.zr1.net/forum/showthread....=rattle+finish
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-24-2016   #5
lfalzarano
Try Mequiar's paint cleaner and/or clear coat safe rubbing compound. You can then finish it off with a polish. Never use a carnuba wax. The engine heat will turn it yellow.
Old 11-24-2016   #6
Fully Vetted
Fully Vetted's Avatar
Whatever you do don't spray the engine down with water when detailing it. Your starter is located in the valley and if your drain hole is plugged up (and it probably is) it will submerge and toast your starter.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 11-25-2016   #7
x2 I highly suggest you go this route
Old 11-25-2016   #8
rush91
I just use a micro-fiber towel, get it damp with some distilled water. But my engine has been recoated, which as stated above by others, makes it easier to wipe down. One thing I do, and this may make some on here cringe, is use a Magic Eraser with a very, very, very light touch.....This seems to work for the little rust stains from some of the bolts. If your getting silver on your rag from the acetone, your just wiping paint off. I would worry about the weathering effects of that
File Type: jpg tmp_17072-IMG_20160405_181852_27684008051.jpg (129.4 KB, 28 views)
Old 11-28-2016   #9
spork2367
Don't use regular simple green or purple power as neither are great for aluminum unless 100% is rinsed off.
This is the over the counter version of the simple green product that is approved for airframe use and is safe no matter how long it is left on aluminum.
https://www.lowes.com/pd/Simple-Gree...eaner/50386662
Exactly the same as the simple green extreme precision and aircraft cleaner but with purple dye and much cheaper.
