Old 08-24-2015   #1
BlackZR1
BlackZR1's Avatar
Default What are these M10 holes for?
Looking up at the bottom of my car just inboard of the front jacking points on both sides of car I see these 4 - M10 tapped holes on a 1" x 3" pattern. (See pic) Anyone know the purpose? Maybe a chassis stiffener mount for convertible cars?
I was thinking of making a couple of 1" thick 6" x 3" UHMW pads to mount there for better lifting / jack stand contact area.
Thanks,
Roger
BlackZR1 is offline   Reply With Quote
Old 08-24-2015   #2
aafc
aafc's Avatar
Default Re: What are these M10 holes for?
Holes were/are for x-brace or frame connectors from vette to vette
1990 white /black #2546
one of a few auto (4l80E ) eq. ZR-1's
Old 08-24-2015   #3
WVZR-1
Thanks,
Roger
Look in the FSM section 10-3-8 or so (varies with year) and there should be an image that might satisfy your curiosity!
Old 08-24-2015   #4
BlackZR1
BlackZR1's Avatar
My underbody braces are missing!!!
Why would anybody remove them?
Maybe to make room for the Borla exhaust?
I'll get under there again tomorrow to see what's going on.
I am not happy, but thanks WVZR-1 for pointing that out.
Thanks,
Roger
Old 08-24-2015   #5
Thanks,
Roger
Roger,
The x-brace was a convertible only add on. You're not missing anything
Old 08-24-2015   #6
BlackZR1
BlackZR1's Avatar
Originally Posted by Kevin View Post
Roger,
Thanks Kevin.
Back to my original plan then.
Roger
Old 08-24-2015   #7
Thanks Kevin.
Roger
If you were looking to get a frame stiffener I'd go with https://www.vette2vette.com/?q=produ...r-bar-system-5
I have one in the garage, just need a lift to instal it
Old 08-25-2015   #8
RussMcB
That's a clever idea, Roger.
I've heard of something similar, from Miata racers. They buy hockey pucks on ebay and bolt them to the frame welds for jacking points.
Old 08-25-2015   #9
Fully Vetted
Fully Vetted's Avatar
It can def be done without a lift. I did mine in about 1 1/2 hours. An hour for the first side and 30 mins for the second.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 08-25-2015   #10
you're a braver man then I am. Maybe I can talk a few guys into doing it at carlise for me
