Old 06-29-2015   #1
GRZR1
Default Imploded Fuel Tank
It DIDN'T fall and rotate, the straps didn't rust or break.... It imploded! See photo.
GRZR1 is offline   Reply With Quote
Old 06-29-2015   #2
Default Re: Imploded Fuel Tank
I wonder how it could have gotten that much vacuum??
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-29-2015   #3
GRZR1
Me too!
Old 06-29-2015   #4
Was the venting blocked somehow? Even if so, hard to imagine the fuel pumps have that much suck ability. Temperature related? Inquiring minds want to know...Bob
Old 06-29-2015   #5
GRZR1
Still trying to figure out the cause. Thinking it could be a blockage in the line from the purge canister. I have been hearing a metal rattling noise for the last couple of summer when the windows are down and I'm driving where the sound reverberates and we realized it was the straps hitting the tank as they loosened. Does anyone know if the ZR1 fuel tank is the same as a regular C4 or special. Obviously I need another tank....
Old 06-29-2015   #6
RussMcB
I briefly Googled imploded tank and saw where it has happened to others. I didn't see any related to Corvettes. Most seemed to be BMWs, and most seemed to think it was related to clogged vents or something similar.
Any codes?
Old 06-29-2015   #7
gbrtng
gbrtng's Avatar
With no research, I'm guessing all C4 tanks are identical - see your local junk yard, they'll know for sure.
Old 06-29-2015   #8
I would have to imagine during the fueling process the mega venting that occured when opening the fuel tank? Never heard of this happening to any C4 before
Old 06-29-2015   #9
mike100
Ok the purge line to the charcoal canister is probably clogged...combined with fueling on a hot low pressure day and/or higher altitude then going to a lower elevation and cooler night temps? It's like taking an empty plastic bottle to a lower elevation...
I'm going to guess the tank wasn't very full of gas too (?)
on a side note gasoline expands and contracts in volume quite a bit with temperature- that's why they say to never top off (when cold out). go somewhere hot and the fuels expands. You never actually fill your tank- there's always a pretty decent air gap for the volume expansion. That said none of this sucked the tank in- that was a pressure difference of air that caused that.
Old 07-02-2015   #10
GRZR1
I Googled it too and found several Corvette sites that explained what "may" have caused it. Mainly a blockage in the vent line to the purge canister.
"Filled" with fuel the night before the tank implosion was discovered. Not a hot day or night, Mid-May, Central Pennsylvania . It took about 8 gallons. Drove it a total of 3.5 miles home and parked it. No codes. Was washing it the next day and thats what I found when I opened the fuel door.
Got a new tank at Corvette America as it's very close to where I live. They want to put this one on display in their showroom when it is replaced.
