Old 09-11-2014   #1
hottrodcrazy
Default 1991 ZR-1 Exhaust Manifold Bolt Specs
I need replacement exhaust manifold bolts for my '91 ZR-1 and the dealership here can't track any down and I'm not finding them online anywhere. Can someone provide me with the specs or tell me where I can find the specs so that I can try to replace them with another bolt that would match?
Or if anyone knows where I can find the bolts that would be great also. Thanks.
hottrodcrazy is offline   Reply With Quote
Old 09-11-2014   #2
Default Re: 1991 ZR-1 Exhaust Manifold Bolt Specs
http://jerrysgaskets.com/store2/root...roducts_id=243
The stock bolts have a sintered metal sleeve/spacer that was held onto the bolt with a retaining clip. We do not have the spacers, but they can be made easily fron 1/4" schedule 40 black or galvanized pipe which is readily available at any hardware store.
Old 09-11-2014   #3
hottrodcrazy
Thanks for that info. I'll look into that. The bolts for the ZR1 are going to be different from standard c4 exhaust manifold bolts I imagine right? I can find those with no problem so I just want to make sure they aren't the same bolts.
