Old 04-19-2014   #1
KILLSHOTS
Default Vacuum leak? Marc has me confused now!
Hey guys,
My vacuum pump (under the pass. headlight) cycles on for a moment every 4 to 5 seconds, when the ignition is on with the car not running. I've come to understand that this indicates a vacuum leak somewhere under the plenum. A no-brainer, right?
BUT, on page 19 of the latest HOTB, Marc says in his troubleshooting tips:
"If the pump cycles on and off the vacuum connections up to the secondary port solenoid are tight. As long as the pump will turn off for one second, the secondary port throttles will operate normally. If the pump shuts off for longer than five seconds it indicates that the vacuum system connections are tighter than average."
So, according to Marc, my vacuum system connections are tight? Am I misunderstanding what I've just read? Anybody willing to help confuse me further?
Thanks!
Chris
Old 04-19-2014   #2
KILLSHOTS
Default Re: Vacuum leak? Marc has me confused now!
Also, forgot to mention that my car idles normally...no high idle.
Old 04-19-2014   #3
Racinfan83
Mine cycles like yours. Runs for 2-3 seconds, off for 4-5 seconds. I took my car to Marc last fall for injectors, coils, radiator clean, and tuning - he said mine was perfectly normal. He drove it with his laptop hooked up to it as well - and all was good....
Old 04-19-2014   #4
JohnG
JohnG's Avatar
Mine does the same. I also thought I had a leak. Glad to know otherwise.
JohnG is offline   Reply With Quote
Old 04-19-2014   #5
KILLSHOTS
WOW, I'm kinda shocked...lots of views but not many replies. Anybody have any thoughts on this?
Old 04-19-2014   #6
KILLSHOTS
Thanks Racinfan, good to know Marc gave yours his seal of approval!
Old 04-19-2014   #7
Blue Flame Restorations
A good working secondary system is a good setup. My 95 works fine...for now. My 91 has no secondary hardware and will never have a leak from that area.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-19-2014   #8
KILLSHOTS
Thanks for getting back, Brett! But my question for you and the rest of our brothers is this:
The conventional wisdom (or my rookie understanding of it) is that a cycling pump means an under-the-plenum vacuum leak. Is that correct? Does my cycling pump mean that I have a vacuum leak? Or do I understand what I read from Marc correctly? If so, John and Racinfan and I don't have leaks. What are your thoughts?
Everybody?
Old 04-19-2014   #9
Honestly, I'm not the person with that specific knowledge. I trust in Marc and Pete. I truly wish I was the expert to give you the answer.
Sincerely
Brett
Old 04-19-2014   #10
KILLSHOTS
Thanks Brett. I'm with you on trusting Marc. I woke up today thinking I had a leak. Now I don't and I didn't have to pull the plenum...I'd call that a good day! LOL
Great night all!
Chris
