Old 05-01-2014   #1
Tony Davila
Tony Davila's Avatar
Exclamation Auxiliary Electric Fan INSTALL
Anyone install an auxiliary pusher fan up front to help with cooling? I am about to embark on a new project. I would like to piggy back off of someones knowledge if possible.
UPDATE! SYSTEM INSTALLED, GREAT RESULTS...READ ON
Tony Davila is offline   Reply With Quote
Old 05-01-2014   #2
Jim Nolan
Default Re: Auxiliary Electric Fan question
Why? I have a 165 degree thermostat and the fans programmed to come on at 185 and off at 180. On a hot day in traffic I never run over 190. You can have your fans reprogrammed thru your chip and do all of what you want. Besides I don't know if there is room for an electric fan. MHA
Old 05-01-2014   #3
Hib Halverson
My guess is it would be difficult to install a aux. pushing fan on the front of the cooling stack. You wouldn't want to put in between the hvac and the oil cooler or between the oil cooler and the radiator because it would likely restrict flow more than it would enhance it.
Know that fans which push are less efficient than fans that pull
If you need better cooling my advice would be:
1) Go to a higher-capacity radiator
2) Seal any holes which allow air flow to bypass the radiator
3) Make sure the OE cooing fans are working properly.
4) Revise the fan-on strategy in the cal
5) Make sure the interior of the cooling stack is free of debris
6) Make sure the front air dam is intact.
7) Go to a 170 or 180° thermostat
8) If possible depending on ambient, decrease antifreeze percentage and add either DEI Radiator Relief or Red Line Water Wetter to the coolant.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 05-01-2014   #4
Tony Davila
Thanks for the info guys, I have 4 core radiator, low stat and Chip reprogrammed. I was just wondering if it would help anymore than my current configuration. Might just tap into the ground side of relay to activate. Still coming up with my operational concept for execution.
You know me I am always trying new things. Remember my water/meth install?
I'll let you know what results I get. Should have it done before BG.
Old 05-01-2014   #5
Originally Posted by Tony Davila View Post
Remember my water/meth install?.
How did that work out ?
Old 05-01-2014   #6
Tony Davila
Exclamation Re: Auxiliary Electric Fan question
Almost 12 HP increase and 10lbs of Trq (temp 64* 12% humidity)
No mods to timing to take advantage of water/meth. Car ran (felt smoother) with the injection on. I notice the difference when on vs. off.
Going to re-run again this Aug at Aaron Scott s when it is hot.
Here's the link.http://www.zr1.net/forum/showthread.php?t=19422
Old 05-04-2014   #7
Tony Davila
Okay finally came up with a game plan and did some testing. I installed a 12" pusher fan at the front of the condenser to help bring in more air while at idle in standing traffic.
What I found is that with the pusher fan on my temp would not rise above 200*. This was at engine idle with both primary and secondary fans activated. Temp remained constant for a duration of 10mins. When I turned the auxiliary fan off the temp then crept up towards 210* and climbing. Slowly....
I know not everyone has problems with this but I have added an aluminum 4 core radiator, 165 thermostat, Fans on at 205 via ECM and still have a creep in temp while in city traffic. This so far has seemed to solve my issue and may for others.
I am piggy back off of the fans ground signal from the ECM to activate the pusher fan when the secondary fan kicks in. This is done through an additional relay. This is so I do not have to hook up a additional toggle switch.
I have also added side curtains and lip to help draw more air in at low speed. 12" Fan is the largest you can fit. Two 12" Fans side by side will fit if desired.
This seems to help as I noticed a quicker cool down and lower temp when driving.
