Hi all,
This is for the coolant system gurus on the net. In the last couple of days I have noted a new a somewhat different cooling problem. My ZR is a 1990 that is box stock . First some info. 1. Issue just started after 2 years of absolutely no problems with cooling or coolant. 2. My Tech and I have totally ruled out a blown head gasket. 3. I am using the good old and approved "green coolant". 4. Hoses are all new Samco and the WP is 2 years old. 5. There are no coolant leaks, anywhere and no coolant smell at all. 6. The system appears to be full with no air locks and the WP pulley is turning. 7. A new OEM NOS 180 deg thermostat was installed 2 years ago. The Problem When I start the car in the morning the temp gauge on the engine and system do not move after 3 to 4 minutes and there is no heat from the heater. When I remove the upper reservoir tank cap there is no flow in the air bleed circuit. After about 5 minutes both gauges begin to move up rapidly especially the system temp. At this point I shut the motor off and wait. I still have no heat from the heater. I go through this a few times and finally the temp will move to the correct reading and the heater hot air comes on and the car settles down to run normally for the rest of the days drive. I can shut it off and restart during the day and everything is OK until the next morning. My FSM and my gut feel would indicate that the thermostat is stuck closed but it doesn't explain all the observations. Any help here would be appreciated. Thanks Don ![]() 0 |
when stats fail they generally fail open, not closed. Had a bad stat on my old DD honda, had no heat at all and the car would frost over save for a very small part on the windshield and the temp gauge never moved higher the 1/4".
![]() Join Date: Nov 2011
We had some bad thermostats floating around. I believe the spring had too much tension?
#4 | |
![]() Join Date: Apr 2007
Bob
#5 | |
Mine have always failed closed or partially open. However I think the OP issue is indeed a stuck thermostat
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 10-09-2013 at 06:53 PM. |
![]() Join Date: Feb 2011
You may have to pull the thermostat to look at it. put it in a pan of boiling water and see if it opens correctly. I have seen more than a couple of thermostats stick open btw.
That doesn't explain the low flow AND the cool temps though??? The only thing that comes to mind is when I have seen bad water pumps with nearly completely eroded impellers due to cavitation from running straight H20 with lots of rusty water. |
maybe its just open 10% and it delays the warmup, but really drive the car and it won't open all the way and runs hot- either way the thermostat is somewhat the easiest thing to take apart for exploratory work.
Hi Don,
The air bleed system should be functional. In my opinion there must be coolant flow from the air bleed inlet into the surge tank. The cooling system on the LT5 is complicated. I suggest sticking with fundamentals and getting the air bleed system working. It might be clogged. There is a detailed description about how to find and fix clogged air bleed lines in the Heart of the Beast issue number 31. A thermostat that is stuck open or closed will not have any effect on the flow of coolant through the air bleed system. Best of luck. Marc |
Thanks everyone for the replies.
Mark, I just reviewed my reprint copy of Heart of the Beast and I could not find any reference to the air bleed system. List, Does anyone have a copy of the air bleed system that Mark was referring to ? If possible could the section be scanned and emailed to me or better yet posted as a link ? I really do want to understand the air bleed design. I started the car and got the same results. It just seems to me that the water is not flowing in the motor when the motor is cold. Perhaps it is the WP after all. Good thing I have a new WP and approved thermostat on the shelf. I was only 2 weeks away from taking the ZR off the road for the winter anyway so it is no big deal but I do want to understand what is happening rather then just throwing parts at it. Thanks All, Don |
#10 |
![]() Join Date: Mar 2004
Heart Of The Beast issue 31
http://www.zr1netregistry.com/Portal...ter/HOTB31.pdf |
