I have a coolant leak at the bottom of water pump/hose. I have removed the passenger side wheel and skirt; lifted the vehicle to gain access to see where the leak is originating. Started the car and no leak. The leaking begins once the thermostat opens. Because of the location and the remaining components in place I could not get my eyes on the source of the leak so I am thinking that the leak is from the hose and not the pump. What say you? Hose or pump. Thanks.
Did you check to make sure the pump is tightened? Inspect the weap hole?
The bolts are tight. The weep hole was dry at startup. Everthing gets wet once the leak starts. I have felt around as best that I can on the hose but do not feeling anything strange. My thought at this point is to remove the hose for a better inspection and go from there.
#4 | |
![]() Join Date: Jan 2009
Either way you need to get her good and hot the get in there with a mirror or whatever it takes to see the origin first hand. I bought an inspection camera from Harbor Freight for just this kind of thing. It has a 1/2in flexible cable with a 1/2in camera integrated on the end. You can get down into crevices to see stuff. At 20% off of the sale price of $69 it was a good investment.
![]() Join Date: Nov 2006
If you pressureize the coolant system to 15 psi it might make it easier to find since it wouldn't have to be started. Autozone rents the tool for that, if you have one in your area.
This may work but may not. In me experience a pin hole leak in a rubber hose needs hot coolant to soften the rubber.
scottfab - believe it or not but my wife suggested trying to get a mirror in place to see what was going on. So I will get one to investigate what the problem is. But due to other commitments it will be several weeks before I will be able to get to this. So the beast will sit. Thanks all for everyones help and support.
#8 | |
Now you can bend the wire/mirror to look at an angle. I actually use the metal sides that are on windshield wipers taped in a similar manor. Works great.
Thanks for all of the suggestions. With some time to think about it and doing some research on tool loans (which is you buy the tool and return it for a refund
![]() Over the last several days I have removed the hoses and water pump and now wait on the replacements to arrive. Several of the hoses were seized onto the metal pipes they were clamped to. It has been real fun getting the hoses off. ![]() When I install the new pump should I use some type of sealant on the gasket? When I replaced a water pump on a 87 vette some years ago I used some don't know about this one. |
#10 | |
