![]() Join Date: Jun 2012
Noticed a little bit oil, under the car the other day. I searched all around the top side of the engine and couldn't see any oil seepage from anything. So, I jacked the car up and crawled under to investigate. There was a film of oil on the oil pan and seemed to dripping from the frame. Had a 100 watt droplight and didn't see any sensors leaking. There was a little oil on the pan screws, but nothing dripping. This cheesy plastic clamp was loose, I'm guessing this is part of the crankcase ventilation, because two metal tubes are joined by a rubber coupling and by the said cheap clamps.
So I pulled the clamp tighter with pliers and retightened the oil pan screws I could get to(really only a couple of them went any tighter, and just barely). Cleaned everything up with a rag and haven't seem any new oil drips, but I haven't driven yet. Hopefully, I solved it. Anyone have a similar problem before? |
#2 | |
See Checking for Oil Leaks/Making your own SS Braided Oil Lines See Potential Oil Leaks and the OPRV Cover Plate ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-17-2013 at 03:19 PM. |
Thanks, Cliff. The link was very helpful. Now, to see if I can get my hand down in there to tighten the OPRV cover, should be fun.
#4 | |
![]() Actually before that I think I removed belt and belt tensioner and went down from top front. I removed and replaced bolts one at a time (not OPRV cover) and used red loctite. Have magnetic pick up tool on hand ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-17-2013 at 09:40 PM. |
Yea, I learned that lesson pretty early. Pulling the engine is not a option, lol. I'll figure some Cro-Magnon way to do it, maybe mirrors and a bunch of swivel adapters. What's the saying.. necessity is the father of invention
