Old 02-13-2023   #1
TexasZR1
Default Not My Car: 1990 Polo Green / Saddle on BaT with Spare Motor; Pot. Pilot Engine
https://bringatrailer.com/listing/19...vette-zr-1-83/
Current bid is 10k.
Posting here primarily because the car comes with a spare engine, so not only is it a pretty good value for a driver / parts / etc, BUT:
It looks as if the motor and transmission in the car MAY be a Pilot motor from the YE8 engineering test vehicle fleet?
The VIN for the donor engine currently in the car may be:
1G1YZ23J3L5800008
Apologies for the poor table formatting...
RPODescriptionMatchesUJ6INDICATOR,LOW TIRE PRESS LOW TIRE PRESSURE IND(UJ6)6,137 UU8RADIO,AM/FM STEREO,CASSETTE,ETR,DELCO/BOSE,DOLBY,INCLUDES CLOCK CASSETTE STEREO(UU8)4,489 UX0SPEAKER SYSTEM,SIX,DUAL FLOOR SILL,DUAL EXTENDED RANGE SAIL PANEL 6 SPKR SYS(UX0)15,101 U52CLUSTER,INSTRUMENT(ELECTRONIC) ELEK GA CSTR(U52)14,963 V73VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)15,538 WD1IDENTIFICATION - PILOT VEHICLE61 XAUUnknown16,016 YBETIRE REAR-(USED WITH ZR1) TIRE(YBE)3,049 YE8ENGINEERING TEST VEHICLE ENGINEERING TEST VEH(YE8)62 ZR1PACKAGE,SPECIAL PERFORMANCE COUPE(1YY07 + ZR1 == 1YZ07) SPECIAL PERFORMANCE PKG(ZR1)3,049 Z51PERFORMANCE HANDLING PACKAGE PERFORMANCE HANDLING PKG(Z51)5,446 19IINTERIOR TRIM COLOR (19I)6,826 193TRIM COMBINATION,BLACK LEATHER (193)6,528 199SEAT BELTS COLOR BLACK (19) (199)6,826 81UEXTERIOR COLOR,PRIMARY,BRIGHT RED (81U)4,960 AC1ADJUSTER,SEAT,6-WAY POWER,BUCKET,PASSENGER 6-WAY PWR P/SEAT ADJR(AC1)13,756 AC3ADJUSTER,SEAT,6-WAY POWER,BUCKET,DRIVER 6-WAY PWR D/SEAT ADJR(AC3)15,562 AJ3RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)16,016 AQ9SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING"ULTIMA"INCLUDES SEAT ADJ(USED WITH TRANS AN Y84) RECL FRT BKT ST(AQ9)8,169 BGRPLANT CODE - BOWLING GREEN, KY, USA16,016 C68AIR CONDITIONER,FRONT,AUTOMATIC,ELECTRONIC CONTROLS A/C AUTO ELEC CONT(C68)15,062 DL8MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC,DEFOG ELEC R/CON HTD O/S MIR(DL8)15,572 D3XUnknown9,029 D74MIRROR,INSIDE,LH VISOR VANITY,ILLUMINATED(USED WITH SPECIAL EDITION WA4) ILLUM S/S MIR(D74)45 D9BSENSOR (D9B)12,387 E5ZADAPTER - SPEEDO - DELETE16,016 E9ZKEY - SPEEDO - DELETE16,016 FE7SUSPENSION SYSTEM,FRONT AND REAR,HEAVY DUTY(PERFORMANCE TUNED)(USED WITH INDY "GT" PKG B5I,GTZ Z04) HVY DUTY SUSP(FE7)5,429 FX3RIDE AND HANDLING,ELECTRONIC CONTROLLED ELEK RIDE & HANDLING(FX3)5,982 GM3AXLE,REAR,3.45 RATIO 3.45R(GM3)3,068 G87GEAR,RING 8.50 INCH 8.50 DIAMETER R/GR(G87)6,426 J55BRAKE SYSTEM,HEAVY DUTY POWER HVY DUTY PWR BRK(J55)5,453 K09GENERATOR,120 AMPERE 120 AMP(K09)3,051 LT5ENGINE,5.7L(5.7J),TPI 5.7J(LT5)3,051 ML9TRANSMISSION,MANUAL 6-SPEED 6-SPD M/TRANS(ML9)6,426 MN6TRANSMISSION,MANUAL 6-SPEED PROVISIONS(MERCHANDISING OPTION) 6-SPD M/TRANS PROVISIONS(MN6)6,426 NA5EMISSION SYSTEM,FEDERAL REQUIREMENTS(USED WITH CALIF SEVILLE YP1) FEDERAL EMIS(NA5)16,016 NK4STEERING WHEEL,SPORT,LEATHER WRAPPED(USED WITH INTERNATIONAL W19,SPORT APPEARANCE PKG W40) LEATHER WRAPPED SPORT STRG WHL(NK4)16,016 QA2WHEEL,17X9.5 FRONT,17X11 REAR,STYLED(ALUMINUM)(USED WITH SPECIAL PERFORMANCE PACKAGE ZR1) SPECIAL PERFORMANCE WHL(QA2)3,049 T93LAMP,TAIL AND STOP(SPECIAL)(DELETES CHROME EDGING)(USED WITH INTERNATIONAL WJ9) SPECIAL TAIL & S/LP(T93)3,049
TexasZR1 is offline   Reply With Quote
Old 02-13-2023   #2
TexasZR1
Default Re: Not My Car: 1990 Polo Green / Saddle on BaT with Spare Motor; Pot. Pilot Engine
An image of the compnine decode:
