I know many people are deleting secondaries these days, but if you are in search of a new canister, I have located one at a ford dealer in south carolina (supposedly the last non aftermarket unit available). I have done some more research and found one at napa that looks identical and have ordered one, so will know for sure by next week. It is napa part #21013 and has 3/16 connectors and outside diameter of 2-31/32". Best part is that it is only $9.99 + shipping in my case. I was told there are 7 in virginia whse. I will check back with results when it arrives. This canister was originally a vacuum canister for hvac on a 76 or 77 Ford f-150.
![]() Join Date: Aug 2006
Great info! I believe this is a correct part. For $9.99, I will order one and hold onto it.
Thank you! |
I met a guy in Prescott Az who was using a Ford vacumn pump, do not remember what car it was made for, small world, Fix Or Repair Daily
I don't think there's likely to be anything 'special' about either the vacuum pump nor the canister. Any pump could be used, provided you are willing to modify the wiring harness to plug in to the different pump. As for the canister, I think it's more about being able to be mounted below the plenum. If it fits, and mounts, then it should work!
![]() Join Date: Jan 2009
Here are some pictures of the Ford part from this website:
http://www.dmauto.com/web/dmauto/Cat...mfg/CRB/21013/ ![]() ![]() ![]() |
Sure looks correct from what I remember!
99 to 2007 Ford diesel trucks, with cruise control use the same vacuum pump with a different electrical connector. Same for Dodge diesel trucks mid 90s to 2001. Check the wrecking yards.
![]() Join Date: Dec 2003
A Kodiak truck has the same Vacuum pump same connector for 1991-1995 the 1990 is different.
I don't have the part # handy but if you do a search you'll find it. Pete
#9 | |
P&G Chevy Price $115.95 https://www.partszoneonline.com/part...=&srch4=&srch5= As Pete states, the vacuum pump is plug & play for '91 to '95, I have one on my car right now. |
#10 |
I received the canister and just cant find a single thing different about it. Even the part number that is stamped on the unit is the same.
