Hello I am preparing to to meet up with some of our Z buddeis to get My girl up and running,..I do have a budget and time so I am posting the question:
*Can I run accel 24lb injectors for the primary/secondary or both? I like accel and I am also looking int ohetting the MSD coil packs as well... *should I worry about the secondary injectors?? what if any mods do I need to run the accel #150824 injectors?? thanks again and lets R ![]() ![]() Dempsey |
if you're swapping injectors do all 16 now
Just Did Mine Do All 16 Carmine1990ZR-1 #357 Black Gray
OK,....BUT will the accel part #150824 work for both primary and secondary???
#5 | |
They will work ![]() Might be tough to get them by Wednesday (for a thursday install) David |
Dave,...THATS the best part!!!!...I can get them anytime,..I have a big speed shop right by the base!!!!
The correct accel part # is 150121. 21Lbs/hr. I forget if its the primaries or the secondaries but you must trim the pig tail lock with a razor on one of them.its not a big deal but I don't think its necessary with the fic's.
#8 | |
![]() Join Date: Nov 2007
The part number you want is (Summit) 150821, both primary and secondaries. And, the is a little tab tha has to be ground off - a Dremel makes short work of that. HTH P. Last edited by Paul Workman; 10-25-2011 at 05:13 AM. |
After much conferring with my Z brethren Im going with FIC's....keep you posted!!!
#10 |
FIC is a 100% best choice for injectors...you will get what you need and without the modification required of Accel's
