Old 09-08-2010   #1
Default Smokey and the bandit
Well after porting the intake, putting on a lightweight flywheel, headers, etc.....turns out the damn engine is in bad shape.
You might recall after hitting a 12.88 Qtr Mile early last year, 6 weeks later the car only turned out a 303rwhp Dyno test.....also some smoke at idle.
Well the smoke is progressively getting worse......will check compression this weekend, looks like I will be pulling the motor for new valve guides, or more
Old 09-09-2010   #2
Aurora40
Aurora40's Avatar
Default Re: Smokey and the bandit
Maybe it's just cleaning itself?
Sorry to hear that. Which car is it that's smoking?
Old 09-09-2010   #3
rhipsher
rhipsher's Avatar
How many miles are on it?
Old 09-09-2010   #4
must be the 90..
Old 09-09-2010   #5
Is the 90 139K miles and was rebuilt at 70.....assuming that they did not replace the valve guides on the rebuild.
Old 09-09-2010   #6
must be the 90..
I'm not sure the sensors were "completely accurate" last night. The right lane only registered 1000' and final time and trap. I ran my best time at
12.7 @ 115.1. Best ET for me but trap was pretty slow compared to my best at 118.6. There was a Nickey Camaro there that was running 12.0@120mph which seemed slow to me for the power it had. Not sure whether GLD traps at the end or in the previous 60'. My Z06 wheels are slightly taller so my rear gear just dropped from a 3.45 to x.xx. On the plus side the new clutch slave worked great and no 2nd gear misses. Also the new tires hooked better on the 1-2 shift. Previously I had to let off in mid track tom regain traction. Overall I wasn't displeased for being the first time out this year. Great night tho for racing with quite a crowd showing up. LOTS of S/C Vettes and Stangs there.
Old 09-09-2010   #7
Looks like new valave guides are about $700.00
ouch
Old 09-09-2010   #8
really? good thing I have a set
Old 09-09-2010   #9
Jeff sorry to hear about the break in at your house later today.....for those prices worth the felony rap
Could this be the end to my lucky ZR-1 streak?
Old 09-09-2010   #10
LMAO.. Dominic has a set too, or just buy his ported heads
