Old 12-10-2009   #1
Aurora40
Aurora40's Avatar
Default Tuning folks, would this stuff work?
http://forums.*************.com/c4-p...-emulator.html
Would that be all that's needed to do tuning on a '90-95 LT5? Are the chips he has needed or even correct for the LT5? I sorta thought those adapter things needed to still retain the stock PROM for the limp-home stuff. But I know nothing about any of this, hence the question.
I currently have cables for datalogging (I use TTS), and I have a wideband device.
I don't really know what I'd change, but it seems like I won't learn anything about it unless I start trying it.
Old 12-10-2009   #2
Default Re: Tuning folks, would this stuff work?
Yes for hardware that should be all you need.. I bet the PROM chips are correct
you use the adapter and your current MEMCAL for the limp home stuff. you read your PROM from your current MEMCAL then you change what you want and program it in the NEW PROM for the adapter
hope that makes sense
Old 12-11-2009   #3
A1990
A1990's Avatar
I am using the G2X pictured in the second link on that thread.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
