Anybody knows where the problem lies? GM manual suggests bad ground or open in the DIM circuit.
If it's reading 1000 RPM's higher, that's pretty typical for a 1990 Model, which i presume you own as these are prone to this issue.
Only fix is to replace the Tach in the cluster. |
![]() Join Date: Aug 2008
Is it just reading high and idling normal?
