Go Back   ZR-1 Net Registry Forums > General > Forum News
Old 08-23-2005   #1
ZR1 MK
Default login required for each post
Its getting ridiculous to login for each post. Is there a setting required to avoid this inconvenience?
ZR1 MK is offline   Reply With Quote
Old 08-23-2005   #2
Aurora40
Aurora40's Avatar
Default
yeah, check the "remember me" button when you log in. And make sure you accept cookies.
Old 08-23-2005   #3
Z Factor
Z Factor's Avatar
Default
I suspect you have an issue with your CPU's settings. In theory you should log in with your ID, password, and check off the Remember me box which I assume you have done. The next time you come to the forum, it should automatically have you logged in, provided you are using the same CPU. Check your cookie settings to insure they are not automatically erased on a regular basis. Also, if you are using any type of anti-spyware program such as Ad-Aware, make sure you only remove the Critical Objects, not the Negligible Objects.
If that helps great, if not let us know.
Old 08-24-2009   #4
ZR1 MK
Default Re: login required for each post
Thanks for your two replies. Ive learned quite a bit since 2005.
Heres the crazy part. I just got notification of the two replies now.
Hope you guys see this now and not in 4 years.
