Go Back   ZR-1 Net Registry Forums > General > Forum News
Old 08-09-2009   #1
Ccmano
Default How do I post more than 6 pictures?
I'm working on a "How to" article that requires more than 6 pictures... 14 to be exact. Is the a way to post this?
Thanks
H
Old 08-09-2009   #2
Aurora40
Aurora40's Avatar
Default Re: How do I post more than 6 pictures?
You can always break it up into multiple posts?
Old 08-09-2009   #3
Thanks
H
Hans,
You can put the pics on soemthing like Photobucket and then use the embed script in the post. The images will appear. You're not uploading to
ZR-1.net. Very limited space.
Old 08-11-2009   #4
QB93Z
QB93Z's Avatar
I use PhotoBucket and I am still limited to 6 pictures.
Is the embed script something different that the photo "img code" link that I use?
Example below:
Old 08-14-2009   #5
Gunny
Gunny's Avatar
The limit is set in the Admin CP and can only be changed by someone with administrator privileges (not me). I'm fairly certain that raising the limit will have a negative impact on the speed/efficiency of the website.
Gunny is offline   Reply With Quote
Old 08-14-2009   #6
YEP ONLY 6 AT A POP
JUST DO A 2ND POST FOR ANOTHER 6
Old 08-20-2009   #7
Ccmano
Found the secret... Photoshop the pictures together so that one image contains multiple pictures. As long as you don't exceed the size limit per picture your OK
H
Old 08-20-2009   #8
H
100k is a small limit. DC has 1mb limit.
