![]() Join Date: Aug 2008
Throwout bearing is broke again. And slave cylinder pin snapped in half. Deja vu all over again. Well, instead of a "plenum pulling party"! I guess I'll have a transmission pulling clutch replacment party. WooHoo!
![]() ![]() P.S this time a fadanza flywheel is going in. And a better clutch. |
Take a look at the LT-1 camaro clutch with a sprung hub for the Fidanza.
Can be found for $69. |
#3 | |
Oh S****T... ![]() |
#4 | |
I would definitely without a doubt be pissed if I had to pull the transmission again !!!! ![]() ![]() ![]() I thought I had it bad enough when mine only needed a dab of grease on the throwout bearing. I know one thing for sure, I probably would have caught it after reading the "BIG RED BIBLE" manuals clutch section, but I owe the guys here at the registry for the warning about the plug in the crankshaft! ![]() ![]() I assume you replaced it also with the newer splined one with a little extra moly grease, right? |
![]() Join Date: Apr 2004
Tell me your kidding. So yesterday, were you telling me this is what I have to look forward to when I start getting more than a few miles on the Z? If so, I'm heading for the roof...
Hang in there and remember, This too shall pass. This too shall pass. This too shall pass. This too shall pass. Last edited by HIZNHRZ; 02-09-2009 at 06:20 AM. |
My god man are your bracket racing that car everyday? I just cant understand how are you having all these issues?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-09-2009 at 01:51 PM. |
When are you going to do it? I am off this week. Maybe I can bring mine over and you can see what my shifter is doing.
Ryan it probably won't be this weekend. Because if I spend anymore money on the king of the hill, the queen of the hill will kill me. So in order to keep the piece I am going to go ahead and sell the 68 mustang and use the money for the Z. I've lost interest in that stang and its just taking up space in my garage. And yes I did have the slave pin in the right spot because it was nice and shinny in the middle like rail road tracks after a 100 car freight train going over them. It took a hell of alot of force to break that pin.
Rick, this stuff should not break, it should not bind when properly installed, unless it was just a case of "cheap chinese junk"
R&R the trans should only take you 3 hours, pressure plate not much more. |
#10 | |
![]() ![]() ![]() Last edited by GOLDCYLON; 02-09-2009 at 01:51 PM. |
