Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Parts
Old 10-31-2006   #1
carnold
Default 90 zr1 injectors
Need a new set of injectors. Where to buy and options available.
carnold is offline   Reply With Quote
Old 10-31-2006   #2
GrayZ
Cool Re: 90 zr1 injectors
accel injectors...less money..summit racing...
Old 10-31-2006   #3
Z Factor
Z Factor's Avatar
Default Re: 90 zr1 injectors
Most either go with OEM or RC's, but some have recently opted for the Accels because of the cost.
Old 11-01-2006   #4
ffvetteman
Where do you get the RC's from?
I cant find them.
ffvetteman is offline   Reply With Quote
Old 11-01-2006   #5
ffvetteman
Also, what about the accel when it comes to durability?
Are they gonna last or go bad like the stockers. I got that crappy gas to worry about.
Old 11-01-2006   #6
tccrab
tccrab's Avatar
RC Engineering:
http://www.rceng.com/
Accel durability, only time will tell.
As that they are designed for the fuels of today they shouldn't suffer from the senstivity to ethanol as the original Multecs.
TomC
'90ZR1 #792 (w/Accels)
Old 11-01-2006   #7
"SOME" say that the spray pattern on the R/C injectors is more like a squirt from a water pistol..... instead of a wide spray pattern from the stock injectors.
Old 11-01-2006   #8
carnold
Decide to bite the bullet and by from AC-Direct.com.$80 primary and $67 secondaries. Plan on fixing originals and saving them for years from now I hope. Thanks for all of your input.
Old 11-01-2006   #9
Jeffvette
Could have bought RC's for less than that, and got a better injector.
Fixing the originals basically ruins them.
Old 11-01-2006   #10
tccrab
tccrab's Avatar
Are you absolutely sure you want to go this route?
My '90 went through 2 sets of GM Originals.
Yes, 2 sets in less than 11,000 miles.
The previous owner of my car had to replace the primaries at some point, and 3 of the 8 GM AC-Delco replacements failed again.
Classic ethanol degredation of internal seals and shorting of coils by ethanol.
They may have updated their design since 1990-92, but I could not find anywhere where this was verified. I tried calling my local dealer's parts department, they don't have a clue. They didn't know anything about the fuel injectors, either.
TomC
'90ZR1 #792
