Old 08-02-2007   #1
Pete
Pete's Avatar
Default UD Pullies
I don't have prooven facts before or after,but to me they are worth there weight in gold,basicly they weign half of the OE steel pieces and if they make more power that is also a plus.
Randy can i twist your arm to make an alimunum PS pullie
I will need a custom made pullie for my next trick on the LT5.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-02-2007   #2
Default Re: UD Pullies
I "think" he makes an aluminum P/S pulley already.
Old 08-04-2007   #3
8upZR1
8upZR1's Avatar
I agree, the underdriven pulleys are worth every penny. I fell in love with them during the first test drive. I haven't noticed any of the problems normally associated with slowing things down. Too bad there isn't enough room to hang a large cogged pulley off the snout of the crank.
Old 08-07-2007   #4
1990 quasar blue
[QUOTE=8upZR1] I fell in love with them during the first test drive.QUOTE]
Can you elaborate?
Thanks
Old 08-10-2007   #5
8upZR1
8upZR1's Avatar
Yes, I will elaborate. The HP increase from the pulleys was noticeable enough for me to feel it when I first put them on, which ussually does not happen with a mere pulley swap. I am not saying that I gained 50 HP or anything but the difference was noticeable, particularly when powershifting, as the car had a more violent side to side wiggle. I dunno #'s but it was a pleasant increase especially when considering that there are hardly any bolt ons available for ZR1's, and even fewer are cheap. Also I have not experienced any problems what so ever regarding engine temp or electrical charge. The pulleys I got were also beautifully machined and fit sans hassle. You can not ask for more from a mere peice of aluminum.
Old 08-10-2007   #6
I spoke with Marc Haibeck about this last week. He advised against it and didn't think much was gained by it. Has anyone ever quantified the effect?
Old 08-10-2007   #7
Pete
Pete's Avatar
Dom,just the weight savings on the drive system is worth it.
You can buy the stock size aluminum pullies between the PS,WP & Alternator it's worth 3-4lbs rotating and dead wieght.
If you think 3-4lbs is not that much next time your at the grocery store pick up a 4lb package of sugar.
For the prices parts are going on these cars you couldn't buy stockers for the price of the aluminum pullies.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-11-2007   #8
8upZR1
8upZR1's Avatar
The GM pieces are retarded expensive, especially if you are replacing all the accessory pulleys. The whole lot, without a crank pulley, will set you back at least a G note.
Old 08-11-2007   #9
1990 quasar blue
Thanks much.
