Old 07-09-2007   #1
72ZR1
Default rear window drain
like to know if any one installed the rear window drain kits and if they work.
72ZR1 is offline   Reply With Quote
Old 07-09-2007   #2
Default Re: rear window drain
Yes....and Yes
Old 07-09-2007   #3
buddyboy
yes and yes
92 ZR-1 #330 White/
yes and yes
92 ZR-1 #330 White/White
buddyboy is offline   Reply With Quote
Old 07-09-2007   #4
buddyboy
yes and yes
Old 07-10-2007   #5
ZR1FUN
Yes and Yes. I actually get a sucking sound the water goes down so fast.
ZR1FUN is offline   Reply With Quote
Old 07-10-2007   #6
72ZR1
thanks every one putting my order today
Old 07-10-2007   #7
Aurora40
Aurora40's Avatar
I put one on my '87 and thought it was a real POS. I got the Mid America kind that came with the drill bit. Well the brass part didn't sit flush, and the lip was so high lots of water didn't drain. Much of what did drain drained between the hose and the body, not through the hose.
But maybe I just sucked at installing it. I just found most of that mid america stuff like the drains and such to be junk.
Old 07-10-2007   #8
bobbyhi
bobbyhi's Avatar
Where are you ordering from??
Old 07-10-2007   #9
SharkPilot
SharkPilot's Avatar
I may be considered a cheapskate but I just use a length of 1/4" vacuum hose to siphon the water out of mine. The end is trimmed so that it can fit down in there better and it gets the water out just fine.
I don't want to trust my clutziness to drilling a pair of holes in the body.
SharkPilot
SharkPilot is offline   Reply With Quote
Old 07-11-2007   #10
72ZR1
corvette central
