![]() Join Date: May 2024
I replaced the oil pressure sensor - 3 prong -part was 1990 Silverado 5.7L - the electric wire clip is broke as well - the replacement with three prongs has three wires - the stock one on the car has 1 wire - will that work and just cut the extra 2 wires?
Arlie 1990 ZR1 #849 |
![]() Join Date: Dec 2003
I think you are mixing/confusing the Oil Pressure Sensor (3 wire) with the Oil Pressure Switch (1 wire)
SENSOR https://www.jerrysgaskets.com/sensor...new-90-95-9b2/ SENSOR CONNECTOR https://www.jerrysgaskets.com/connec...-1990-95-15d1/ SWITCH: https://www.jerrysgaskets.com/switch...new-90-95-9b3/ SWITCH CONNECTOR: https://www.jerrysgaskets.com/connec...-1990-95-12b5/ ![]()
Looks like i might - according to the pic i am dealing with 12555492 - but it definitely only has one wire -
#4 | |
