Old 12-27-2023   #1
AndrewL
Default Air Conditioning Compressor Clutch availability
It looks like my AC clutch is toast. I've searched here and online extensively without finding a definitive answer. I suspect the one listing for a ac clutch compressor to suit a ZR-1 is erroneous because it lists it as being compatible with both base cars and ZR-1's.
Can anyone confirm if the clutch is available separately or do I have to buy a whole compressor to get a new clutch assembly?
Link to the ad which I suspect is erroneous: https://www.topflightautomotive.com/...ressor-clutch/
AndrewL is offline   Reply With Quote
Old 12-27-2023   #2
Default Re: Air Conditioning Compressor Clutch availability
There is some info in regards to the clutch I believe on this site somewhere. This is an issue that's been addressed before so the info is out there. At one point I had planned on getting a spare for my stash. Google A/C clutch ZR-1 and it should pop up.
Old 12-27-2023   #3
1991 Corvette ZR-1
Been barking up this tree for a bit. If I may add to the confusion, from the same site there is a listing in the link below for a clutch that ?fits? 1990 ZR-1s only. To my knowledge, there was no difference in the pulley diameter, connector or clutch design that is different year to year for ZR-1s. Unfortunately, these sites have a lot of help that is not familiar with specialty vehicles within the Corvette brand.
https://www.topflightautomotive.com/...SABEgLSdvD_BwE
Old 12-27-2023   #4
geezer
AC clutch for base L98 is #10158036. LT5 # is '90 # 10158044 &'91 is #10157970.
Compressor for base L98 '90-'91 is #10135601. LT5 '90-'91 is #10090565.
As per part #'s base & LT5 are not interchangeable?
geezer is offline   Reply With Quote
Old 12-28-2023   #5
I started looking for the clutch and assorted parts a few years ago and got side tracked,I'm on the hunt for a clutch coil if anybody happens to see one. Part number for the coil is 10157969 I believe.
Old 12-28-2023   #6
I just checked ROCK AUTO and they have the clutch assembly.
Old 12-28-2023   #7
AndrewL
You guys are brilliant.
Thank you, finding out the part numbers was next on my to-do list. I appreciate you sharing the information. I'll also email that vendor to let them know their listing is incorrect.
Thanks Jeff, just placed an order for the clutch with them.
Old 12-28-2023   #8
I believe the 1990 Clutch has a different electrical connector than the 91-95, but I could be wrong. I know it changed on the L98 cars my 89 connector and the 1991 connectors for the L98 cars were different
Old 12-28-2023   #9
I bought the last GM clutch coil they had.
Old 12-28-2023   #10
1991 Corvette ZR-1
I see those on RockAuto, but are they for DOHC? I would not think Chevy would allow something like a different AC pulley diameter for an LT5. I have an old screenshot of that same clutch and the old site I got this from stated it fits DOHC compressors as well.
