Old 08-21-2023   #1
combja
Default cruise control drops out
My cruise control will set, drop out when braking and resume normally, then just drop out randomly.
Then, sometimes it will Resume on demand, sometimes not. Sometimes it can be re-set, sometimes not.
Turn it off/on then sometimes it sets, sometimes not.
Wait awhile, turn it on, set it and it will work for a while, then randomly drop out.
Any suggestions?
combja is offline   Reply With Quote
Old 08-21-2023   #2
Default Re: cruise control drops out
Any suggestions?
Do you have a FSM? There is a helpful diagnosis tree to follow.
Old 08-23-2023   #3
Young1
Young1's Avatar
Yes FSM. Check 30 year old vacuum hoses for cracks at bend going into module above battery. Probably minutely cracked. Trim off an inch or so and reinsert.
Steve Young
Second Owner
SOLD
SOLD
Old 08-24-2023   #4
combja
What is a FSM?
Old 08-24-2023   #5
What is a FSM?
Factory Shop Manual or more correctly Factory Service Manual. They have diagnostic schemes for finding a vacuum leaks or other malfunctions. --Bob
Old 08-24-2023   #6
Also check for cracks on the vacuum line supply in the middle of the passenger side of the plenum
Old 08-28-2023   #7
Thomas ZR-1
Thomas ZR-1's Avatar
Check the vacuum switch down on the brake pedal...often cause leaks in the system.
[SIGPIC][/SIGPIC]Best thing in life is a ZR-1 ride
Thomas ZR-1 is offline   Reply With Quote
