Old 12-09-2017   #1
mlubahn
Default WANTED: Cam position sensor and Dual mass flywheel for 1990 ZR1 LT5
Hello. Looking for a camshaft position sensor for my 1990 ZR1. From what I understand, there are a few part numbers: 10096172 and 10137658. Possibly more???? Please let me know if you have one, new or used. THANKS!
Maybe a dual mass flywheel too!!!!
Please let me know if you have either
mlubahn is offline   Reply With Quote
Old 12-09-2017   #2
Young1
Young1's Avatar
Default Re: WANTED: Cam position sensor for LT5
I am looking also. All I have found is 239.95 at napa. Whew! Any leads are appreciated.
Old 12-10-2017   #3
Ccmano
Default Re: WANTED: Cam position sensor and Dual mass flywheel for 1990 ZR1 LT5
PM sent...
H
Old 12-10-2017   #4
Young1
Young1's Avatar
Mr. Dynamite. Jerrys link submitted is for a crank sensor. Jerry has no listing for cam sensors. Any other suppliers anyone can share?
Old 12-12-2017   #5
WVZR-1
Some potential after-market other than the NAPA selection BUT only for the later 10137658 which is also the NAPA interchange.
WELLS - SU1101
SMP - PC110
AIRTEX - 5S1254
AUTOPART INTERNATIONAL - 1802-302169 (couldn't confirm with an image)
When the GM 10137658 was used to replace the 10096172 there were GM notes that mentioned a different shield GM 10199080 likely required.
10096172 seems to have been used '90 & '91 with the 10137658 potentially in later '92+ builds.
If your '90 is apart it might be interesting to compare the shield differences with snapshots.
Old 12-13-2017   #6
I have an AIRTEX in my car,think it was $200. As stated the original shield won’t work with this part.
Old 12-18-2017   #7
Young1
Young1's Avatar
Gentlemen, I am desperate to purchase a camshaft positioning sensor. A month ago napa had five within the country, now they have none. I have used all of the part numbers I have called manufacturers I have spent hours on the Internet and I have come up blank. I waited until I got my bonus last Friday and that was too long. My car backfired coughed stumbled and died in traffic Saturday evening. Started right up after I stopped though. Code 31 once again. Desperate in Florida.
Old 12-18-2017   #8
Ccmano
I hesitate to say it but White Racing Products in FL. shows one in stock. $296.00
These guys are a craps shoot
http://www.whiteracingproducts.com/i...roducts_id=596
The next site has a listing of dealers that supposedly have them in stock. Good luck!
http://oemcats.com/oem-parts/10137658.html
H
Old 12-18-2017   #9
Mystic ZR-1
Mystic ZR-1's Avatar
FWIW: Have your injectors been replaced?
Code 31 was just one of the spurious codes that
showed up when my injectors crapped out...
Old 12-18-2017   #10
Jagdpanzer
Jagdpanzer's Avatar
Default VRe: WANTED: Cam position sensor for LT5
Wonder if there is an alternative sensor out there that could be adapted to work in place of the original OEM cam sensor?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
