![]() Join Date: Oct 2017
Found a PBR master cylinder to replace the original on my '90. It was beginning to seep a little out of the cylinder bore. The new one is exactly the same as original except the PBR logo font is a bit different. It also does not have "Made in Australia" cast into the housing as the original did. The box it was shipped in does indicate it was made in Australia.
Would like to repair my original, but am having no luck on locating an overhaul kit. Does anyone know if any have become avasilable? Thanks Guys & Gals !! ![]()
Kenny 1990 #442 ![]() |
I would think this is easily available considering how many C4s were produced.
#3 | |
Steve from Crossed Flag Performance and I have been looking all over for a few years. NAPA used to have them, but that was before I was checking around. And yes, I did check about stock on individual store shelves to no avail. Just feel fortunate to locate an OEM replacement. ![]() Edit: I did a quick check again for an overhaul kit. Appears Eckler's may have some. Everybody else shows not available. The kit from Eckler's is $169.99!! Wow! Think I will disassemble mine and see what parts it needs. I have repaired some cylinders in the past just by matching the seals. No hurry I don't guess. Doubt anyone would know the one on my car is not original except me. ![]()
Kenny 1990 #442 ![]() Last edited by TX '90 ZR1; 02-22-2022 at 07:59 PM. Reason: addition |
![]() Join Date: Nov 2007
I have had good luck with the M/C & slave combo from Rock Auto. Both (mine) are cast iron (not the Chinese or that tubular steel junk).
For (anyone's) information: The '90s clutch line between the MC and the slave was a solid steel line. And, if you ever need to replace it, it is a "bear" to weave it around between the (what have you) and the MC and SLAVE. Furthermore, the bleeder on the slave is on top of the 90 slave cylinder; a real PIA to try to bleed the clutch (system) of air or to change fluid, etc.* But! The clutch line for the 91+ years has a flexible section in the middle which makes it easy to install and orient to the respective cylinders. And! The slave for the 91+ has the bleeder on the bottom side of the cylinder which avoids the access issues when manipulating the valve when purging the system. I installed the '91 line & slave on my '90 with NO issues! I wrote an article for HOTB (Registry member's quarterly) with more detail and photos on the whole MC/Slave installation, if interested. ![]() The bottle from the Mitivac kit shows how it looks when mounted to the reservoir of the MC. The SLAVE is the TOP view of the '90. I recommend** purchasing a slave from the 91+ years. (The bleeder valve is opposite to the one pictured (the '91+ are on the bottom instead of the top)). This method can be done w/o an assistant, and only requires (about) 3 to 5 cycles to bleed out all of the air and end up with a firm pedal (IOW, NO AIR in the system!) ![]() **if/when you convert from a '90 to a '91+ slave, you will need to purchase the '91+ clutch line too. I think you'll find the new one much easier to install than removing the old '90 hard line! Last edited by Paul Workman; 03-01-2022 at 02:32 PM. |
