Old 04-29-2021   #1
bowtiguy
Default looking for stock brake rotor thickness measurements F & R
My car came with aftermarket brakes and I'm looking into installing stock brakes for a short period while I get a wheelset made for the car.
Specifically, I'm looking for the rotor thickness AT the mounting point to the Hub face for BOTH front and rear rotors if anyone can put a caliper to a spare pair they have laying around. Thanks!
bowtiguy is offline   Reply With Quote
Old 05-03-2021   #2
bowtiguy
Default Re: looking for stock brake rotor thickness measurements F & R
No one has stock rotors laying around?
Old 05-03-2021   #3
Roadster
Roadster's Avatar
Hello bowtiguy.....I do....but they have been resurfaced....my brain is not working at the moment.....so from the hub to the back of the rotor is the measurement you are looking for......correct???
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-03-2021   #4
bowtiguy
they will work fine. Resurfacing of the braking surface wont effect the area I'm looking for a measurement of.
I'm looking for the thickness of the rotor where it mounts to the hub. Same area where the wheel studs protrude through.
Old 05-03-2021   #5
Roadster
Roadster's Avatar
Haha.....finally after reading and thinking about this a 1000 times over....lol my brain is working.....the measurement I have is 0.291" that is for the front rotors.....the rear rotors are still on the car......but I would imagine that they would be very close if not the same measurement.....hope this helps...
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 05-04-2021   #6
bowtiguy
Most definitely, thank you sir!
Old 05-04-2021   #7
Roadster
Roadster's Avatar
Glad to help out....[emoji16][emoji16]
Sent from my SM-G981U using ZR-1 Net Registry mobile app
1974 LS4 454 Vert
1974 L-82 355 Vert.
