Old 08-30-2020   #1
kz098123
Default Crooked exhaust tips?
While I browse for my first ZR-1 for sometime in the near future, Im noticing some have crooked exhaust tips, where the outer tips sag a bit. Is this a common issue? Is it easily corrected? Or is it a PITA/costly to fix?
kz098123 is offline   Reply With Quote
Old 08-30-2020   #2
billschroeder5842
billschroeder5842's Avatar
Default Re: Crooked exhaust tips?
For me it is more of an illusion than anything as the rear valence panel "scoops up" at the ends.
I do admit that it annoys me too.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 08-30-2020   #3
tf95ZR1
tf95ZR1's Avatar
I had a discussion (arguement?) with Borla about this.
They had a booth at a car function and I spoke with
their sales rep. When I questioned my inability to level
the tips, his response was that it was due to each C4's
"variability" and there was nothing they could do about
it.
When my car was up on a rack I mentioned it to someone
who said, "I can fix that!" He got a torch to heat up one
of the tips and try to turn it. All he succeeded in doing
was to melt my plastic inside wheel well liner!
Another adventure with a ZR-1.
Ted
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 08-30-2020   #4
G8nightman
G8nightman's Avatar
Some exhaust are adjustable I?m running SW
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 08-31-2020   #5
I feel your pain! Simple fix tho. Tac weld All of the joints along the entire length of the tubes. The issue is that unless you do, heat cycles combined with (potholes etc) will result in the pipes succumbing to the torque introduced by the lateral weight of the mufflers. Clamps just don't hold long before they slip...and they will slip!
So, once the tips LOOK* right, tac 'em in place "as is"!
*This from an article re aligning iron sights on guns, but applies there to, methinks: "The human eye is very good at detecting angular (and especialy light) variances"
. If the edge of the valence or the optical appearance of the valence compared to the angle (or the appearance) of the twin tips is misaligned, then regardless of what an actual level (used to level the tips) may indicate, arrange the angle of the tips so they LOOK right and WELD all of the joints (ideally) or at least TAC WELD the joints. Otherwise, it's only a matter of time before the tips will sag (twist) down toward the outboard side of the valence.
Old 08-31-2020   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Not a bother at all......................
Went with a large single tip.
But even if there were two, you can't hardly tell...................
The concave nature of the factory installed CORVETTE letters is a far "sorer" thumb than the way down there tips on my ZR-1.
Thank goodness the build quality has improved dramatically over the last 25 years!
But, who cares, LOVE is blind! (almost)
Marty
Old 09-03-2020   #7
ZWILD1
ZWILD1's Avatar
My black 91 had an early B&B 3" system. I was always adjusting and repositioning the tips. The clamps while tight would allow for the pipe and muffler to move. It was a bit of a pain in the butt. I put a 3" B&B on my 96 LT1 coupe and had the same issues with it. My current car has the 2.5 " Corsa and those tips are rock solid. I have never had to mess with them.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 09-03-2020   #8
BigJohn
BigJohn's Avatar
Do they not cost extra?
Old 09-03-2020   #9
billschroeder5842
My Corsa is rock solid as well.
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 09-03-2020   #10
If u have done mods to the motor, the left side torques over and twists the tips. Exhaust needs to be tack welded. Clamps just can?t hold it.
You may even need to beef up the hanger stud on the body of the muffler. The flexing may eventually rip the skin of the muffler.
