Old 08-24-2020   #1
902066
Default 335/35zr17 tire
Thinking about putting Michelin 335/35zr17 tires on factory 11 inch wide amold rim. Has anyone had problems or regrets after doing this? I don't really want to switch to a 18 inch rim and tire. Thanks Jim
902066 is offline   Reply With Quote
Old 08-24-2020   #2
Dime
Default Re: 335/35zr17 tire
The Toyo r888r comes in the stock front and back sizes if you?re having trouble finding stock size tires.
Dime is offline   Reply With Quote
Old 08-24-2020   #3
Zman
Toyo r888r Tires are great sticky tires.
Zman is offline   Reply With Quote
Old 08-25-2020   #4
dredgeguy
dredgeguy's Avatar
I am on my second set of Michelin 335/35ZR17's. The first set were on my A-Molds rims and the second set on my Fikse FM5's. Perfect fit for both. They are not cheap but found some savings getting Costo to special order them when the had a special on Michelin. I think they are the best touring tire, quiet, long life and great dry and also in the rain.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 08-25-2020   #5
I put them on the '95 back in 2014. They were great tires and no problem fitting the car. I had a set of Sumis that were very difficult to balance and one of which was so far out of factory specs it couldn't be balanced even on a Road Force balancer. Bought the Michelins from Costco for $1,700 (back then) and they installed and balanced them without problems and without a Road Force. They were great tires bought at a good price from Costco, enjoyed until I sold the '95 in 2016. --Bob
Old 08-26-2020   #6
Vetman
Vetman's Avatar
Yes put them on in 2013, have 20,000 on them and show very little wear. Still stick well. No clearance issues. 1990 z stock wheels.
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 08-26-2020   #7
Mary59
Mary59's Avatar
From what I read in the reviews, they're great. I always trust Michelin more than other tyre manufacturers.
Here's my website. Please visit if you're interested
https://www.nybizdb.com/
Mary59 is offline   Reply With Quote
Old 08-26-2020   #8
902066
Thanks all for your reply's. If I decide to go ahead with them I won't worry about fitment issues. Jim
Old 08-26-2020   #9
gtcollins@maxnet.co.nz
gtcollins@maxnet.co.nz's Avatar
When you fit the 335 on the back do you fit wider tires on the front
Sent from my SM-G973F using ZR-1 Net Registry mobile app
gtcollins@maxnet.co.nz is offline   Reply With Quote
Old 08-26-2020   #10
dredgeguy
dredgeguy's Avatar
No as Michelin makes the front tires in the stock size of 275/40/ZR17
Charlie
__________
Dredgeguy
Dana 4:10 gears
