Old 03-15-2020   #1
90zr1blknred
Default Pilot bearing knocked out my engine plug
Help I have a 90 zr1 I was replacing the pilot bearing on and I knocked out the engine plug behind it. Any tips on how deep to set my new plug since I don't have a reference now. And tips or tricks to set it right. Thanks everyone.
90zr1blknred is offline   Reply With Quote
Old 03-15-2020   #2
Ccmano
Default Re: Pilot bearing knocked out my engine plug
The search feature for this forum is your friend. It’s what makes the big difference between a forum like this and Facebook. The later being very difficult to search.
The following thread should help. Good luck and don’t worry, this stuff happens to all of us.
H
http://www.zr1.net/forum/showthread....ght=Crankshaft
Old 03-15-2020   #3
90zr1blknred
Thank you so much
Old 03-15-2020   #4
tf95ZR1
tf95ZR1's Avatar
By "I knocked out the engine plug behind it" do you mean
pushed the rear engine seal into the engine? Can that happen?
That would be no bueno.
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
tf95ZR1 is online now   Reply With Quote
Old 03-15-2020   #5
90zr1blknred
Yes I popped the plug into the motor and need to install a new plug after I tear the entire clutch and flywheel out again. Ugh.
Old 03-16-2020   #6
Yeah...pushing it through...is different than pulling it out. It happens sometimes. But, I don't recall what (perhaps it was Marc H) may have said about it. Is it a "biggie"?? IDK either.
I'll camp on this one....
Old 03-16-2020   #7
90zr1blknred
No big deal. It drops into the oil pan and you put in a new one. I’m told it will be ok if I set the new one correctly. More worried about not screwing that up and what the best depth is to put it back in since I have no reference as to where it was originally. Ugh
Old 03-17-2020   #8
Jagdpanzer
Jagdpanzer's Avatar
The rear crankshaft cup plug seals the lube oil bore in rear main journal. There is another pressed in cup plug located forward of it to seal the other end of the bore.
The dislodged cup plug should be fished out first before installing a new plug. Be sure to thoroughly clean the rear cup plug sealing area with suitable solvent and install using Loctite 620 and J38837 rear cup plug installation tool according to FSM instructions.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-18-2020   #9
Jagdpanzer
Jagdpanzer's Avatar
Sorry, can’t understand your question.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-18-2020   #10
90zr1blknred
Do you have any thoughts on how to fish this out given that it was a tight seal engine plug that was pushed in. I fear it won’t come out but Haibecks thought was that it would just drop into the pan and wouldn’t be an issue. I appreciate the different thoughts here as I’m not certain what the effects could be if I can’t get it out.
