Old 04-23-2020   #1
Corvette95
Corvette95's Avatar
Default Bosch Injectors - Is this correct oring set up?
I have read the threads on injector o'rings, I am replacing the IH O'rings, I have ohm'd these injectors all are good. This is how they came out, is the o'ring set up correctly and properly identified.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 04-23-2020   #2
Bradjon
Default Re: Bosch Injectors - Is this correct oring set up?
One thin guy to look for is the spray pattern . My checked out ok till I took off plenum and turned on fuel pump and 2 just sprayed a stream
Bradjon is offline   Reply With Quote
Old 04-23-2020   #3
Corvette95
Corvette95's Avatar
But do the rings look right for the primary and secondary ?
Old 04-23-2020   #4
Ccmano
Here is how mine looked on my 90’ when I was running Bosch injectors. I can never remember which was primary and which secondary however only one has the O-ring mounted to the injector. The other has the O’ring mounted in the injector housing.
H
Old 04-23-2020   #5
Corvette95
Corvette95's Avatar
Set up looks the same, the primary should be on left of your photo with orange tip the on on the right is secondary...right?
H
Old 04-23-2020   #6
tf95ZR1
tf95ZR1's Avatar
Free: Thanks, Jerry! Jerry's Gaskets
https://www.jerrysgaskets.com/lower-...llation-guide/
http://www.zr1specialist.com/HAT%20W...eplacement.pdf
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 04-24-2020   #7
For what it's worth here (maybe) the Accel injectors (part # 150821 @ Summit Racing) which many, many ZR-1s are running on are identical, i,e., they both have provision for an O-ring at the injector tip. However, on the 1990 ZR-1 ONLY, the ridges provided to hold the O-ring on the tip of the primary injector can be ground off @ your discretion. (Theoretically, the ridges left on provide a bit of turbulence in lieu of the injector boss [often removed as part of the full porting of the 1990 IHs] to promote better atomization of the fuel.)
