I have changed my fuel filter 3 or 4 times over the last 19 years, never noticed there being o-rings either in the filter or on the fuel lines, never had a leak.
Changed my filter last week, again didn't see any o-rings, but now for the 1st time I have a small fuel leak. Looked in Solutions and it mentions o-rings. So my question is are their supposed to be o-rings and if so are they on the lines or the filter body, and possible what size because my new $16.00 filter didn't have any included. Thanks for any help Jim |
#2 | |
![]() Join Date: Nov 2007
![]() Edit: WVZR-1: Thanks for the update. ![]() Last edited by Paul Workman; 04-09-2019 at 11:12 AM. |
Thanks for your reply Paul. I just looked at the Service Manuel page 6c-5 and it does show o-rings on the fuel lines but I have never noticed them. I guess I'll take it apart, see if there is a space for an o-ring and try it again. I cant believe if there were o-rings I have never noticed them.
![]() Join Date: Oct 2004
GM# 22514722 (217-452 ACD) should get you the required o-rings @ the filter. Buy from a dealer or ACD jobber. All fuel lines and the filter are M16-1.5 Saginaw style and require seals.
I just replaced the original fuel filter on my 91' w/ 9,600 miles ( recently new to me) and can confirm they were there form the factory. Mine were in good shape so I reused them. Easy to replace if it starts to leak unlike the fuel rail assembly I just rebuild while doing injectors and top end refinish.
![]() Join Date: Aug 2006
![]() Join Date: May 2010
Nice to know. Never seen or heard of it until now. Never had a leak with new fuel filters over the past 16 years and two Zs. Thanks for sharing and the info.
