Old 07-06-2018   #1
rkreigh
Default LSV = zero rwhp
sheesh, been a tough summer, I confirmed the lsv had a serious issue as it hydro locked trying to start. I had been battling a coolant leak and "coolant smell" for years after going to samco hoses
one of them blew on me a couple of months ago and although I was able to get the car off the road right away, getting it home it ran hot (240)
a few weeks later, the coolant leak started to get just a little worse, new hoses didn't fix it and I couldn't find the leak. Oddly enough I didn't see any coolant in the oil (changed it, and kept checking the dip stick), but for sure it was eating coolant.
I tried to start it up a week ago and the engine just refused to turn over and the starter was grinding gears. Sure enough, I pulled the plugs and hit the started and saw the "LSV memorial geyser" and coolant shooting up out of the spark plug hole!
At that point, my heart sank as I thought "how am I ever going to be able to fix this"
soooo....... apart it comes. top end and cooling stack are out, rad was really blocked up, new stronger fans going in from dewitts to keep it cool with ac on.
going with the haibeck MLS head gaskets as they should be a bit better and more forgiving.
check everything out and we'll see what else needs to be done. Demps looked at the porting and it definitely reflects 1997 conservative thinking and may have a bit of room to grow.
Now comes the hard part, getting this thing done in time for Carlisle.
right now I'm a bit bummed. I have 3 vettes and all are down
last night the old pooch 944 turbo (parts chaser) had the clutch go to the floor and stay
I think I need to take up raising chickens or a slight less expensive and less stressful hobby.
I'm going to go fly a model airplane and think about what color engine to go with and quit whinning and start wrenching!!
Went to harbor freight and found a cool tilt a hoist for 39, and a tranny "short scissor" jack for 99 that will work with my 4 post lift and make the tranny pull much easier.
like larry says "get er dun"
Old 07-06-2018   #2
HAWAIIZR-1's Avatar
Default Re: LSV = zero rwhp
Sorry to hear this Ron! Best wishes with the build and I’m sure it will come out great and even better!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-06-2018   #3
Young1
Young1's Avatar
Sometimes the hard part is just getting started. Set a time pull out the toolbox and get after it. Then one thing leads to another and the money starts flying out of your wallet Got to love it
Old 07-06-2018   #4
Vette73
800 RWHP Z06? That would satisfy me....
Old 07-06-2018   #5
tpepmeie
you need bigger cams too
Good luck Ron. Let me know if I can help.
Old 07-07-2018   #6
That LSV had a long healthy life (IMO). Port work has come a very long wat since that engine was put together by JL...…………...hint.
Old 07-17-2018   #7
rkreigh
engine is out! I will have the heads off soon now and see what failed.
I'll keep you all posted. for sure the porting will need some updating.
Old 07-18-2018   #8
Ron, I know you want to get it ready for Carlisle but you know you would have fun even if you had to go in a rental car. My advice is to take your time, relax, lower your stress levels and do it carefully and correctly. Plan it out. Everyone will get to see it at some point soon I am sure. Best of luck on it. --Bob
Old 07-18-2018   #9
rkreigh
I have a feeling I'll be vetteless for a while
I have big plans for the lsv to give it some fresh blood
dragons blood
porting, fresh rings and hone, bearings, and clean the old gal up for the next dance
we are cracking the cam covers off and pulling the heads to get started.
no hurry, you can't drink fine wine until it's ready.
Old 07-18-2018   #10
tccrab
tccrab's Avatar
Ron:
If you need a few new RC planes to fly while you're 'Vetts are down for repair, you can borrow a few of mine.....
'Crabs
