Old 10-22-2016   #1
Ami Workman
Default New Struts
We are getting parts for Ms. Turq Monster... a telescoping hood strut and some struts for the back too... getting the winter projects lined up 😉
Ami Workman is offline   Reply With Quote
Old 10-22-2016   #2
Blue Flame Restorations
Default Re: New Struts
In good hands, for sure
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 10-22-2016   #3
Make sure you have a block of wood handy during the process. That's glass is pretty darn heavy
Old 10-22-2016   #4
Ami Workman
Old 10-22-2016   #5
cvette98pacecar
Are you talking the prop rod or pressurized hood lift support?
Old 10-22-2016   #6
Mystic ZR-1
Mystic ZR-1's Avatar
Do the two little ones on the hood while you're at it.
Makes the hood easier to open and they're inexpen$ive too.
<88 C4s had them. The mounting studs should still be there.
Old 10-22-2016   #7
Where are you ordering the hood prop rod from? I need a new one
Old 10-22-2016   #8
Mid America. Ami looked it up in their catalog, because their web page SUCKS so bad (doesn't cross-reference worth a damn) that even the rep on the phone couldn't find it.
Anyway...
Ask for part # 609-623 "Telescoping hood support strut"
Lists for $59.99, but shipped it runs $80.xx from Effingham.
Old 10-22-2016   #9
prop rod, for now...
Old 10-22-2016   #10
Anyway...
Ecklers C4 Corvette Hood Support
With New Hood Support the hood can easily be lifted and will stay lifted without locking the support (all ZR-1 hood supports loose lift after a few years and should be replaced).
If the old Hood Support is not making the Hood lift easy with the fingers and if that support does not easily hold the Hood Open (within the last foot of hood movement) then you need a New Hood Support.
