Old 09-24-2016   #1
MuRCieLaGo
Default o2 sensor left and right have different numbers?
Hi,
It's been a while since last time I posted here. Can't work on the car, I'm on a ship since June and until November.
However I'm starting to order some parts.
I've seen on eBay a guy selling NGK NTK o2 sensors, left and right have different numbers. Haven't touched the ZR-1 since a while but if I recall, both left and right are supposed to be the same, right?
Links:
http://www.ebay.com/itm/NGK-NTK-Oxyg...5Xaeve&vxp=mtr
http://www.ebay.com/itm/NGK-NTK-Oxyg...RXae35&vxp=mtr
Thanks for your help!
Old 09-24-2016   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: o2 sensor left and right have different numbers?
Get them from Jerry's then you know they are the right ones.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 09-24-2016   #3
Hib Halverson
I've never used an NTK sensor in an LT5, but the listing I found on Rockauto.com shows PN 12003 fitting both left and right. Only NTK and Walker list their sensors as fitting right and left even though it's the same PN.
Always used Denso O2Ses in my LT5 because they have great durability.
I might add that Rockauto.com beats that eBay vendor's price. NTKs are 31.89-ea and Densos are 28.79-ea.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 09-24-2016   #4
MuRCieLaGo
So Denso is cheaper and better? Sounds good, will order 2 from RockAuto.
Denso are also the same left and right?
Thanks for your advices!
