Old 01-31-2016   #1
Default On pulling front fascia off a 92
My front fascia had a defect when I first bought it, w the passenger side corner having cracked paint. I'm in the process of removing fascia and thought I would ask if anyone else has done this. I've removed all the bolts along the fender well, front air dam, top along the hood (what a PITA, especially the two corner TORX screws). I see that there is a center retainer but can seem to see the bolts from behind. Any hints are welcome.
Thx.
Old 01-31-2016   #2
Default Re: On pulling front fascia off a 92
FSM has instructions
Old 01-31-2016   #3
I looked at that. Think I may need to unbolt the side marker lights.
Old 02-04-2016   #4
The side marker lights will cause the edge of the bumper to hang up as you pull the cover off and can't forget the 2 small screws on the bottom of the bumper by the foglight access panels. I've done this job,pretty easy and straight forward.
Old 02-04-2016   #5
Thanks. Yeah I got the small screw tucked underneath. It does feel that marker lights need t be undone. Just waiting for a bit warmer weather. Those torx screws at the corners are a PITA. No room between hood and facia to get a wrench in there.
Old 02-04-2016   #6
BigJohn
BigJohn's Avatar
Okay!
Doug I didn't say it !
Old 02-04-2016   #7
Mystic ZR-1
Mystic ZR-1's Avatar
Originally Posted by BigJohn View Post
Okay!
Old 02-05-2016   #8
BigJohn
BigJohn's Avatar
Originally Posted by Mystic ZR-1 View Post
Sawzall
