Old 04-08-2015   #1
Pat Cooke
Default Heater Blower
My heater blower continues to run when the ignition is switched off ?
Is it the resistor or relay. Can anybody advise. I have removed the resistor which could have been getting hotter than expected.
Regards
Pat
Pat Cooke is offline   Reply With Quote
Old 04-08-2015   #2
Default Re: Heater Blower
Its the Blower motor resister control module thats on the firewall next to the blower motor. This controls the speed of the motor and the attached squirrel cage. Since the motor contines to run after the key is off the resister on the control module is fried. Not a ZR-1 specific part so any C4 replacement for your model year should work. GC
Old 05-21-2015   #3
Pat Cooke
Hi,
The new heater blower resistor cured the problem with the blower fan staying on. Thanks ! Now the INFL / REST ( inflatable restraint) warning light is on, also the red logo in the instrument panel.
Can you advise please.
Regards,
Pat.
Old 05-21-2015   #4
Originally Posted by Pat Cooke View Post
Hi,
Regards,
Pat.
Infl Rest
Old 05-21-2015   #5
As Cliff as pointed out time to clean the front impact sensor grounds. Common problem on all MY 90s
Old 05-21-2015   #6
Mystic ZR-1
Mystic ZR-1's Avatar
efnfast
Check the 1st 3 posts to this string.
Sound familiar?
Old 05-21-2015   #7
tf95ZR1
tf95ZR1's Avatar
efn, what turned out to be the problem with your car @ BG?
Old 07-04-2015   #8
Pat Cooke
http://www.zr1.net/forum/images/smilies/fahne19.gif
All fixed !
Many thanks for your help !!
Regards,
Pat
Old 07-04-2015   #9
efnfast
Regards
Pat
Pat, was it the fan only? I had issues where the CC display would not shut off, even with the key removed from the ignition. It resulted in a no start.
Old 07-04-2015   #10
efnfast
Best we could come up with was that something was keeping the CC live. This in turn would not allow the starter to engage. We push start the car, or unplug the fuse for the CC and the car would run fine. After the car was started, we could plug the fuse back in and all was ok. Not sure if it was rain related or not. It was pouring when it happened.
