Old 11-07-2015   #1
Johnny5
Default double din install & quality Qjuestion
hi guys, so installed the nav/bluetooth headnit without trimming the bezel as i got the 6.1inch screen. My only question is does anyone else hroave white noise with the radio on. I was told it i bc you have 2 amp (headunit & amp on each speaker) and it causes distortion. ANyone else expeience this? Any solution to fet rid of the static/whitnoise?????
Can you bypass the stock amps to get rid of distortion
Johnny5 is offline   Reply With Quote
Old 11-07-2015   #2
Default Re: double din install & quality Qjuestion
Is it same pitch tone or alternator whine?
Old 11-10-2015   #3
Locobob
You need an adapter if you are going to use the stock bose speakers and amps with an aftermarket head unit. I'm using the PAC OEM-1.
Robert
Old 11-13-2015   #4
Johnny5
thanks loco bob. Did anyone post a how to for a double din install with pics or very detailed? I've been wanting to get this done for some time now after staring at the kenwood box for months
Old 11-20-2015   #5
Johnny5
The only thing i need photos of is what to dremel cut to make sure my double din fits all the way in.
Old 11-21-2015   #6
lisounds
lisounds's Avatar
every double din radio is "slightly" different
so take yor time, insert radio and trim a little, as needed.
some time you have to cut the back plastic wall behind the radio to achieve the proper depth.
and the front factory bezel has to be filed a bit as well.
take your time its easy
lisounds is offline   Reply With Quote
Old 11-21-2015   #7
Don't try to cut it. It's impossible to cut straight. Use masking tape to mark how much trimming you need and use a grounding wheel and file to grind it down. 90-91 car bezel don't need much trimming.
