![]() Join Date: Nov 2013
Been enjoying my ZR-1 and driving as often as I can, but now having some running issues.
1995, stock with Corsa catback, Screamin Demon coils, and Livewires spark plug wires. 68,xxx miles. Drove it to work Friday morning, seemed fine. About a 50 mile commute one way. Left work to come home and started running a little rough, loss of power, no difference with power key on or off. Felt like maybe some bad gas. Drove it a lot over the weekend to burn off some fuel. Put in a can of Seafoam and filled up with fresh gas. Drove it to work Monday and same thing. Tuesday morning was the same thing but coming home Tuesday it got worse. Didn't want to hardly rev. Idle so bad at stop light that dual mass was making noises. Pulled plugs, all looked the same and replaced about 8,000 miles ago. Checked ohms through wires and coils: 1-6 9.03k 2-3 9.3k 4-7 9.07k 5-8 9.00k Didn't drive it the rest of the week. Saturday took it out a bit and not as bad, felt like something "freed up" a bit like it could breath easier. Rev'd easier, idle not as bad, still not perfect and still low on power. Got on it and got a exhaust smell, took a lot longer to get up in RPM's but it would. Decided to go ahead and pull the converters to check them out as it seemed like an easy thing to do. After being under there maybe not so much. Looks like possibly 3 bolts won't be so bad but one doesn't seem to have any room at all. So, does it sound like I'm on the right track or should I be focusing elsewhere? Can't see any messed up vacuum lines, don't hear any vacuum leaks. MAP and fuel pressure regulator lines are good. Went ahead and replaced fuel filter as well and no change. |
![]() Join Date: Aug 2012
Have you changed out the injectors? Your issues are very similar to what I had when I purchased the car. Changing to stainless steel injectors took care of it. Found out 7 were bad and lucky I made it from CT to MD. You might also change the fuel filter.
Good luck and keep us posted.
Sorry, you took care of the fuel filter..........now if the injectors are stock, you know where the problem is.
![]() Join Date: Apr 2004
Did you check the fuel pressure?
Thought about fuel pressure, will go pick up a gage tomorrow and check that. I know injectors were a common problem on the earlier ZR-1's, but didn't think the later ones really had any problems with injectors?
Got in the garage this morning and this is where I'm at.
Fuel pressure, cold, key on engine off 48 psi. Idle 44 psi, stayed there as it warmed up. Remove regulator vacuum line 53 psi. 2000 RPM 43 psi. After shut down stayed at 48 for 10 minutes, disconnected pressure gage after that. Took some catalytic temp readings Driver's side Front of cat 380F Rear of cat 650F Passenger side Front 350F Rear 460 Still making me think a problem with the cats. OR is it running way too rich on the driver's side and causing the cat to work harder and causing the higher temps? Last edited by fletchusmc; 12-28-2014 at 09:51 AM. Reason: Added last sentence |
#7 | |
![]() Join Date: Nov 2007
With the ignition OFF, an ammeter connected between the positive battery post and the fuel pump diagnostic connector (the short red pigtail jutting out of the wire harness next to the diagnostic connector which is toward the middle, near the ECM). Configuring the meter to read amperes... ![]() Connecting the meter to the fuel pump test jumper: RED LEAD TO POSITIVE POST, BLACK LEAD TO THE TEST PIGTAIL. ![]() BOTH pumps are powered ON and you can measure the current. Each pump will draw about 4 to 5 amperes ea, for a total of 8-10 amperes. ![]() While the pumps are running, you should measure about 53 psi (again w/ ignition switch OFF). If your current is about half of what it should be, and/or the pressure is not up to par, then pulling fuses (as Jerry suggested) will isolate which fuel pump is not working (NO pressure with the ignition ON). As for injectors...anything is possible, but the 93+ cars had injectors that were alcohol tolerant, and less likely the issue...BUT never assume. BTW, you should always check electrical coils (ignition and injectors too) when they are at operating temperature. A bad coil will often read normal resistance until they are heated up. |
![]() Join Date: Dec 2003
I think you need to isolate the primary fuel pump by removing the fuse for the secondary fuel pump. The cold readings you observed would be the results for both primary & secondary pumps operating together.
The secondary pump will shut down after coolant temp reaches about 170F ( I forgot the actual number). You did state "stayed there as it warmed up." but actual temp is unknown so the secondary pump may still have been running. Good news is there is not a significant injector leak. I have no input on the converter temp, just the fuel pressure test. I'm sure you will get it resolved.
![]() Join Date: May 2007
If it is still idling poorly I would approach it from that angle. It's easy to work with in the garage. You have good fuel pressure at idle. A clogged catalyst usually won't effect the idle. The faces of the catalyst substrates can be viewed through the oxygen sensor hole.
Do a spark test. The spark should be at least 1/4" long, blue and make a nice snapping sound. |
#10 |
I appreciate the help so far. Life, work, and the holidays have kept me out of the garage lately. However, the Marine Corps is sending my girlfriend on an expense paid trip to Quantico for a week so I'm looking forward to plenty of garage time and will keep all of you up to speed on what I'm finding out.
