Old 08-15-2014   #1
Default Rebuilding Top End #3032 (Last 1990 Sold)
Well....same ole same ole
I am rebuilding the Top End on #3032 the Last 1990 ZR-1 sold to public (57K miles).
Everything removed/restored/replaced on Top End (Plenum, Secondary Vacuum system, HVAC Vacuum, Plugs, Coils, Starter, Crank Case Vent Cover, Alternator, AC Compressor (not disconnected).
This is my standard Top End Restoration.
This time I will leave the Water Pump as there are NO leaks at all and ALL bolts were tight.
1. Replaced Power Steering Pulley with Billet Aluminum Pulley.
2. Replaced Belt Tensioner Pulley with Billet Aluminum Pulley.
3. Replaced Crank Case Vent Cover Gasket (several loose bolts - use Red Loctite).
4. Replaced Aftermarket Spark Plug Wires with LT5 Original Plug Wires.
5. Blocked TB Coolant at Injector Housing (appearance is as stock).
6. TB Coolant Return Line to Coolant Surge Tank Blocked.
7. New Spark Plugs.
8. New Secondary Port Throttle Linkages.
9. New RC Injectors (SL4-205s).
10. New Primary and Secondary Injector "O" rings.
11. New Plenum Gasket (use NO gasket sealant of any kind as there is NO Coolant.....Dry Gasket- NO Loctite).
12. New Crank Case PCV "L" hoses under Plenum.
12. Reconditioned Vacuum Canisters (shined up).
13. Reconditioned Starter Solenoid (wire brush contacts on plunger).
14. This time I had to replace bearing on Solenoid end of starter armature (it was a bit rough).
15. New Radiator Hoses with rounded edge clamps.
16. Checked all Coils for proper and consistent resistance.
17. Reconditioned Coil Plate (shined up).
18. Checked Alternator Bearings and shined up Alternator.
19. Replaced Fuel Line "O" Rings at Connection Rear Passenger Side of Plenum.
20. Replaced Injector Housing Coolant Manifold Gaskets and bolts (Use Heat to remove original Torx bolts).
21. Checked ALL Injector Housing Bolts for tightness (Did NOT remove Injector Housings as there were NO oil leaks).
22. Used light Steel Wool (0000) and Simple Green on Plenum and Cam Covers (Will leave Stock Look without Painting or Powder Coating).
23. Removed cover (six 4mm Torx 20 bolts) and dried out TB Coolant Area above TB. Will Replace this cover with Carter Billet Aluminum (ZR-1).
24. More when I think of it (takes three days......one day to disassemble, clean, and repair broken parts, one day to think, and one day to put back together and fire it up)
NOTES:
Everything Degreased and HOT WATER Pressure Washed when TOP END Disasssembled. This included clearing the Valley Vent through Bell Housing.
Oh....LT5 ran great (I thought) but found four bad Injectors (resistance 10 ohms, 10 ohms, 6 ohms, 6 ohms)
Compression checked earlier and ALL Cylinders 215 lbs within 5 lbs.
ALL Fluids were Replaced (Engine Oil, Transmission Oil, Differential Oil, Coolant) and Differential Drain Plug Installed Earlier. Haibeck Chip and Starter Relay were also installed earlier.
Typically I check and locate ALL vacuum leaks on secondary system but this LT5 had NO Vacuum Leaks (Secondary Canisters functioned perfectly BEFORE Start of Top End Restoration).
Old 08-16-2014   #2
Schrade
Default Re: Rebuilding Top End #3032 (Last 1990 Sold)
Old 08-16-2014   #3
Sweet!! You are a passionately OCD documenter. Must be the engineer in you.
Old 08-17-2014   #4
Did turn the key for Vacuum Pump and NO vacuum leaks so must have connected ALL vacuum hoses correctly
TB coolant is now blocked but you cannot tell by looking
All new RC SL4-205 injectors and some other stuff
Fired it up and it ran perfectly ......even with TB Coolant BLOCKED
Old 08-17-2014   #5
That is why I now will call him the
"Detailed Dyno Documenter"
Or "Triple D" for short
Old 08-17-2014   #6
Which by the looks of it....NO ONE can tell TB Coolant Blocked at Injector Housing. And.......those hoses for TB Coolant are brand new WITHOUT Clamps (why have clamps when there is NO Coolant Pressure).
Those RC SL4-205 Injectors run sooooo smooth
Again...this three day Top End included one day for disassembly and repair/restoration of parts, one day for thinking, and one day for re-assembly (including a test drive up to 120 mph).
Note:
The Nice RC Injectors Red Stencil on corner of rear lift top glass.
Old 08-17-2014   #7
Hey good job and way to go DDD.
Or should it be 3XD or D3X or TriD
Old 08-17-2014   #8
Schrade
Need to borrow my camera and tripod there Cliff?
Old 08-17-2014   #9
Thank you...
I like Triple D
Triple D sounds like something to do with Corvette Babes which is ALL good
Thanks for all you do and especially like what you have in your signature
Old 08-18-2014   #10
"Triple D sounds like something to do with Corvette Babes which is ALL good"
Like the Triple Dipper?
http://www.urbandictionary.com/defin...riple%20Dipper
OH wrong link - I meant the Triple D available from you local Walmart
No doubt the Vette Babes would like this very much
http://www.walmart.com/ip/Crock-Pot-...Black/21154908
