Old 08-18-2014   #1
Default Clutch Master Replacement
Well here was the issue complete failure of the Master....rod came completely out:
Old 08-18-2014   #2
Default Re: Clutch Master Replacement
You need....
took about an hour....
10MM socket
13MM Socket
13MM line wrench
7MM Socket
Phillips Screwdriver(small)
Extensions
Torx head set up to 30 Torx
Old 08-18-2014   #3
*Loosen the 10mm nuts on the ECM....place to the side..
Master is under the ECM
*Remove the ECM bracket: unbolt the 10MM bolt to the cross brace, unplug the MAP sensor
*Remove the battery (Torx heads and 10MM socket to lower fender/battery cover) 13mm for hold down behind battery(don't forget the 10mm bolt on the top of the panel....its covered by a piece of weatherstripping)
This will allow access to the master
Old 08-19-2014   #4
The Master is held on with two 13mm bolts that feed through the fire wall....
First remove the hydraulic line from the master
The outside bolt is easy to access with the battery removed
The second you will need to feed a few extensions with a swivel through to get to the bolt..
Old 08-19-2014   #5
inside the car, remove the lower panel
Two 7mm bolts on the front
Two screws on the side....and some underneath
Old 08-19-2014   #6
Once inside slide under the panel with a light....to the upper left you will see the master, the only thing holding it on is a clip
The clip is difficult to remove and put on....however its easy if you use a flat blade screw driver to gently open it while pulling it back
Master is out...reverse the process....add fluid pump clutch bleed. Not bad!
Old 08-19-2014   #7
Excellent writeup, Lee!
Old 08-20-2014   #8
rkreigh
anybody have some of those *&^%$#@!!! clips laying around. when I replaced the master on the LSV mine was taken by the goat legged bastard
all I heard was a little "ting" when I didn't quite get it on there right
the other thing "stange" to me is that the stock part had a "spacer" and the replacement master has that cast into the base of the part
my replacement has a noticeably different feel to it (not really as good as the stock one)
I'm tempted to rebuild the stocker and put it back on.
Old 08-20-2014   #9
Scrrem
Scrrem's Avatar
Ron,
Send you stock one to Jim Janik, he will rebuild it good as new!!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 08-20-2014   #10
I think this is the clip
http://keenparts.com/pages/detail.ph...partnum=340095
