Old 05-22-2013   #1
Bob Lyle
Default Engine loses power when starting off.
My ZR1 runs good most of the time. This only happens once in while, when starting from a stop in first gear the engine stumbles, loses power and may back fire. After several seconds the engine regains power and is ok. This only happen when taking off and the car is up to temp. Any ideas would be appreciated.
Bob
Bob Lyle is offline   Reply With Quote
Old 05-22-2013   #2
Default Re: Engine loses power when starting off.
my car is doing the same, I think its o2....
Old 05-22-2013   #3
As noted it may be the O2 heating up
I changed prom, ECM, etc still doing it....leaves the o2 I believe, someone with a tech 1 or scan tool should be able to ID the issue
http://www.zr1.net/forum/showthread.php?t=20069
Old 05-22-2013   #4
Bob Lyle
Smile Re: Engine loses power when starting off.
What is o2
Old 05-22-2013   #5
Oxygen sensor; its going bad, bad ground etc....confusing the ECM and altering fuel causaing a lean or rich condition
Laymans terms...a sensor that sniffs the exhaust, checks to see how rich or lean it is, then tells ecm to add or trim fuel
Old 05-22-2013   #6
Mystic ZR-1
Mystic ZR-1's Avatar
Bob
We can check for any codes on Sunday
D
Old 05-22-2013   #7
mine does not throw a code when it happens, does yours?
Old 05-22-2013   #8
Bob Lyle
I have had it scanned several times in the past, but never while it was happening.
No error codes ever came up. This has happened since I bought the car 97. Care presently has 36k on it. I can go several weeks with no issues.
Old 05-22-2013   #9
Mine does not show codes, I noticed a change in the 02 readings when it happens....I have not swapped mine yet but plan to do so...
Old 05-22-2013   #10
Lee,
I'm pretty sure my AutoXray gives dynamic TPS readings (just another thought). If so, we could see if the TPS isn't glitching - or any other sensor; O2 or whatever for that matter!
P.
