Old 07-20-2014   #1
echerbst
Default Complete lt5 engine and zf6 trans
Complete lt5 engine and zf6 transmission
I have a complete motor and trans out of a 91 zr1 for sale. Bought a complete wreck a year ago that I parted out. Was going to swap in a camaro but plans have changed. Engine has 100k miles on it with brand new injectors and fuel pressure regulator. I did a leakdown test on the engine and all cylinders were less than 1%. Super tight engine. Previous owner said it was a real screamer. Engine is complete with ecm, wire harness, and all accessories. The transmission was replaced about a year or so before I got the car. It has a shorthrow shifter too. Engine was very well maintained and a strong runner at 12.0 at 119mph before it was pulled.
3000 for motor
1400 for trans with fresh clutch and shifter
300 brand new fidaza aluminum flywheel
Call me at 312-933-5083 if you have any questions.
echerbst is offline   Reply With Quote
Old 07-25-2014   #2
zrwhat
zrwhat's Avatar
Default Re: Complete lt5 engine and zf6 trans
Erik,
I can vouch for you on this one, car was mine at one time and the car did run those numbers while it was mine and motor had zero port work and was running factory injectors at that time, very strong runner indeed.
If you don't get any serious interest in the motor, contact me, Love to have that one as a spare and I know the motor well and know its a good one.
Jeff Gibson
zrwhat is offline   Reply With Quote
Old 07-31-2014   #3
spork2367
PM sent.
