Old 10-08-2013   #1
KJL
Default Secondary Vacuum Solenoid Foam Filter
While cleaning around the solenoid I accidentally tore the very back of the foam filter off the secondary actuator solenoid. 80% of it is still there, most of the black part, but there is an exposed small hole in the center. Are there replacements for these? Should I just attempt to glue it back together?
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
