Looking for some help or something that I missed. I am working on a 1990 Corvette ZR-1. The vehicle originally came in and the dual mass flywheel was banging like crazy at idle. I ordered the brand new injectors from FIC and replaced both the primaries and secondaries. The idle misfire was greatly improved and 4-5 injectors were bad 3-4 ohms and about 3-4 were questionable under 10 ohms. The vehicle has new spark plugs, coil and oxygen sensors. There is still a slight miss at idle BLMs rich at 115 and INT around 89-94. If I drive the car down the street it is fine at part throttle, but once you try to go WOT in normal power mode the car falls on its face misfires like crazy and will not clean up. Turn the switch to full power mode and it will stumble for a split second and then accelerate normally. I have already checked fuel pressure, and I have spark with a tester on all cylinders including 2 & 7. Did a compression 215 psi and leakdown and everything checks out. If I pull the plugs they all look normal except 2 & 7. Both of these plugs have a good amount of carbon buildup. I also saved the old plugs I removed before I started this job and noticed 1 plug from each bank was more carbon'd then the rest of the plugs. I don't know weather it was 2 & 7 but I assume it was. At first I was thinking maybe I received 2 bad primary injectors but the plugs before the injectors kind of ruled that out in my mind.
I was thinking maybe a bad ECM ?? Suggestions please help Last edited by J & J Speed Shop; 07-23-2013 at 02:26 PM. |
Welcome onto the boards there...
![]() Join Date: Mar 2004
2 & 7 share the same coil.
Wire's on right ? Bad wire's on 2 & or 7 Coil bad |
#5 | |
Yes I have the wires firmly on the coils as well as the spark plug end. The coils are all brand new and I checked the one wires and had approx 17,000 ohms of resistance on the number 2 which is a long wire |
Oops 4 & 7 - 3 & 2
Check 4 pin connector at the coil pack maybe not connected right. Arching wire. Mile's on car ? |
![]() Join Date: Apr 2007
Did you eventually figure out what the problem was? It sounded from your initial post that you were quite thorough in your work, but there are a few idiosyncrosies to these engines. If not, and if you have not done so already, you might contact Marc Haibeck (website www.zr1specialist.com). He should be able to shed some light on it. Good Luck--Bob
![]() Join Date: Jan 2012
Double check all the vacuum lines especially the map sensor , this could cause some of the symptoms you described. Hope this helps..jimmy
#10 |
