View Poll Results: Best way to extend battery life for stored cars?
Disconnect negative lead for duration 1 7.69%
Leave battery hooked up to a battery tender 11 84.62%
Other (post your method, please) 1 7.69%
Voters: 13. You may not vote on this poll
Old 02-02-2013   #1
vilant
Default Dead battery
Last week when I tried starting it (it's been sitting for a couple of weeks), I got the clicking of a dead battery. I jumped it w/ another car (although after reading an old post after I did that, where someone fried there BCM, I'll never do that again) and she started right up, and I let it run for 15-20min. Figured I drive it around today and give it some exercise and maybe recharge the battery again. Unfortunately it wouldn't turn over berfore the clicking of a dead battery was back. I know the battery shouldn't be more than a few years old (at least the PO told it was changed recently), but the car has been sitting a lot before I got it and little bit recently. I've also been working inside the car, so the interior lights have been on more than they should have.I bought a battery charger and I'm trickle charging at 2A for @14hrs (charger recommendation, I also disconnected the battery leads, just in case).
My question is how to do you best preserve the life of your battery? At least for those who have to store their car for long periods of time (don't think LA or Vegas drivers have to worry to much about this). I'm not sure if just starting it, and letting it run, really charges the battery.
Or is just disconnecting the negative lead good enough?
Or do you leave it connected to a battery tender?
Old 02-02-2013   #2
Default Re: Dead battery
Battery tender
Old 02-02-2013   #3
Originally Posted by vilant View Post
My question is how to do you best preserve the life of your battery? Or is just disconnecting the negative lead good enough?
I disconnect the negative battery cable if I know it is going to sit for a week or more. I use an 8 mm flex head ratchet wrench I keep in the center console
Old 02-02-2013   #4
RICHARD TILL
My experience is that a brand new battery will be discharged after about 6 weeks of sitting.
Old 02-03-2013   #5
Fully Vetted
Fully Vetted's Avatar
Battery Tender. That's what they were made for.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 02-03-2013   #6
Battery Tender (again). Battery in the Z is more than 5 years old, and the one in Ami's 69 C3 is 8 years old - both on BTs, both crank like new - even in winter!
Soon as they're put in the garage, the Tenders are hooked up and they stay connected until the next outing.
P.
Old 02-03-2013   #7
efnfast
I use a tender. Only during winter storage, car rarely sits for more than a week in driving weather.
Keep in mind, 5-7 years on a battery is pretty good these days.
15 minutes of engine run time is like being a big charger for 15 minutes, not really that long to fully charge the battery.
Good quality batteries will certainly last longer than cheap ones. -Steve
Old 02-03-2013   #8
scottfab
scottfab's Avatar
I've been using a battery float changer since 1997.
Disconnecting a battery does not prevent hard sulfation.
Best practice is still the a battery float charger, however on the horizon is a new type of charger (de-sulfator) wish promises to be even better. Price could be an issue but technically speaking "the best" approach.
Read about it at the bottom of this article. I've been tracking this technology.
http://batteryuniversity.com/learn/a...to_prevent_it/
One example of an intelligent changer de-sulfator is:
http://jlzg.en.alibaba.com/product/6...esulfator.html
PS. a Kleenex is a general term for tissue but is a specific brand.
Tender is a specific type/brand of "float charger".
Scott
Old 02-03-2013   #9
efnfast
Nice article Scott, thanks.
Old 02-03-2013   #10
vilant
I read the article on sulfation that Cliff had in Solutions. It talked about sulfation while the battery is discharging, but I was wondering if it happens while the battery sits. Apparently it does. Makes you wonder how much it occurs while it sits on the shelf, before you buy one. Was also wondering if just running the car in idle charged it, that article says it doesn't, which is also nice to know. Looks like I need to add a Tender or float charger or maintainer to my inventory. Thanks for everyone's input, it helps a novice like myself a lot.
