![]() Join Date: Nov 2007
Saw this on CF ZR-1 page, and it was news to me. Thought I would share w/ y'all.
http://www.tirerack.com/tires/tirete...adj_Zspeed.jsp Your Thoughts??? p. |
Paul,
Looks like 40psi would be good overall. I think this chart addresses sustained speeds. We won't be up there for very long. |
![]() Join Date: Nov 2006
Interesting
![]() Join Date: Jul 2005
When we were doing the mile at Nellis AFB a few years back we used those charts. Good info...
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
![]() Join Date: Dec 2012
In road racing at VIR their standard club's inflation info to new road race course racers with three straights on the course was to add 3-5 pounds to your normal tire pressure which I believe was to keep the sidewalls stiffer and from less flex on cornering. The chart referenced seems like a lot to me and I have a question.
Does it presume high or low aspect ratio tires? I'd think it would be slightly different for the two. With our 40 and 35 aspect ratio tires mine with very small changes in air added seem to make pretty solid changes in air pressure and are much stiffer in terms of side flex with the shorter aspect sidewalls we have. My 76 is 255 x 60 tires and now we're 275 and 315 and 35 and 40% which are pretty rigid on the car comparatively. Lance P.. |
