Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 07-08-2012   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default cleaning engine bay
what is the best way to clean the engine bay.. Not the engine itself but all the road grime and junk around it. Please dont say by hand... LOL
RiceEatingZR1 is offline   Reply With Quote
Old 07-08-2012   #2
Default Re: cleaning engine bay
Pull the motor.
Old 07-08-2012   #3
mike100
Before mine broke this spring, I carefully used a pressure washer about twice a year- mostly around the radiator and front suspension and frame area where all the road grit accumulates.
I actually do lightly blast the heads with the spray, but wash the engine at your own risk until you are experienced enough to know where the water should not go (mostly by hand).
Always wash a cold engine (the TPS sensor may crack inside if a rapid temp change occurs). Also would be good to know if your plenum drain plug is open or plugged.
Old 07-10-2012   #4
RiceEatingZR1
I was thinking about bagging the motor with plastic bags and painters tape than carefully using pressure washer around the engine bay.
