Old 06-12-2012   #1
efnfast
Default Change oil light
Does my '90' have the ability to calculate when the oil needs to be changed, or does the light come on at a certain mileage. As a side note, it turned itself back off. TIA. - Steve
Old 06-12-2012   #2
Default Re: Change oil light
i'm 99% sure it's mileage based.
Old 06-12-2012   #3
VetteMed
Not mileage based - it's a rev counter, basically. There's a complex algorithm based on number of engine revolutions, and oil temperature, and possibly some other parameters.
Old 06-12-2012   #4
efnfast
VetteMed, they could do that in 90 with OBD I? And, why did it go back out. Maybe it assumed I always drove like a nut and, well, I guess I always do.
Old 06-12-2012   #5
VetteMed
Yep, as long as there's a crank position sensor, the number of revs can be monitored.
Not sure why it would have gone out, though. That's odd to me.
Old 06-12-2012   #6
efnfast
Does it normally come on with "key on"? Maybe it goes out after a certain number of key starts? Seems unlikely. Maybe the bulb poped.
Old 06-12-2012   #7
scottfab
scottfab's Avatar
To check for popped light just turn the key on.
The dash lights all come on briefly.
Scott
Old 06-12-2012   #8
mike100
My 95 LT1 car used to get around 5500 mi between change oil lights based on my driving routine. I'm expecting the same for my 91 w the LT5, but i will keep an eye on the mileage just in case. I don't really like to go over 6-7k on oil changes unless it is all highway.
Old 06-12-2012   #9
rhipsher
rhipsher's Avatar
I believe it. Mine comes on every 1,000 miles. I rev high allot. And mine drinks way more oil than 1 quart every 2500 miles. More like 4 quarts.
Old 06-12-2012   #10
John Boothby
John Boothby's Avatar
It is based on rev's and temp. However, it must be reset each oil change, and it is a bit more complicated then it is resetting the fuel milage computer.
