Took my ZR1 to an autocross last weekend for the 1st time and wow what a blast, I've been on a high all week. I'm already anxiously awaiting the next event!
The balance and power of the zr1 is simply amazing. I've only autocrossed 2 times before, once in a GT Mustang and once in my 69' TR6, and while those were fun, the performance doesn't even compare. My tires are a little old, and that combined with cold damp conditions made it tricky. I found my best times by short shifting to second and keeping the revs down to help keep the rear end in check. Although I'd really like to pickup some new sticky tires, I was still able to get 1st in my class (B Street Prepared), and 3rd out of ~20 novices. Anyways, just wanted to brag. Next event is in 2 weeks, hopefully I'll get some video. Anyone else autocross their Z? Any input on tires, tire pressure, or alignment settings? -Jordan |
#2 | |
![]() Join Date: Jul 2005
Don't know anything about the settings, etc. but good luck in 2 weeks ![]() Keep the rubber side down............... ![]() |
Sounds fun! I have never done it but would love the opportunity!
![]() Join Date: May 2007
Thanks for telling us about you experience at the track. Try posting a specific question about setting in the General Section. You will get a lot more responses.
Jim |
![]() Join Date: Dec 2004
Waaay cool! 1st in class!
![]() You may want to call Doug Rippie or have a look at Dick Gulstrand's site for alignment suggestions....maybe even vette brakes & products might have something. I would say maybe a set of Nitto NT05's or INVO's maybe; unless you want to have a set of dedicated track tires and another set for street use? I know that this may sound stupid. In our pizza boxes is a small spiral bound book with the splash logo on it. That book is an owners' manual specific to the ZR-1, and it it there is an "off road" section. In that section it has a suggestion of alignment settings for track use....there is a whole bunch of info actually that I found good reading, JMHO. ![]() ![]() Tom
Hit the autocross again today, here's a couple videos:
Interior (very shaky)- http://www.youtube.com/watch?v=fY81J9M9DA8 Exterior - http://www.youtube.com/watch?v=5JShaLf_EWc Ended up getting 2nd in class, but still aways off the BTD. Car did GREAT, hope to get a new set of tires before the next event and maybe look into tweaking the alignment a little. |
![]() Join Date: Mar 2010
Thanks for the videos!! That looks like a real blast!!
Any hints on performance improvements you made or anything you learned about the car doing this? Thanks! |
Had a drivers education event and another Auto-X this weekend.
This was my first event with the new alignment described in this thread: http://www.zr1.net/forum/showthread.php?t=14320 Here's the specs: FRONT Camber: -1.5 -1.6 Caster: 5.5 5.6 Toe in: 0 0 REAR Camber: -1.2 -1.2 Toe in: 1/8 total (1/16 per wheel) Really like the changes. Thought about trying to toe out the front a little, but didn't take the time. The cornering is noticeably improved, and, with a few tweaks to my driving style, kept the rear end a little more in control ![]() Possibly against my better judgment, I ran this weekends event with the top off. The weather was just too nice ![]() Next event is this Saturday. |
#9 | |
I'm learning a ton each event, but most of that applies to my own driving. The car really has amazing performance in stock form. Mine has a few engine mods but, for short course racing like this, I think before modifying the engine I'd look into a lower set of gears to help get your Z into the power band faster and keep it there. As it is, the courses are a little fast for 1st, but 2nd never gets me into the meat of the power. A little more extreme alignment (as I mentioned above) helps a lot, as will purpose built tires (hopefully I can report back on that soon). The only change to the suspension on my car is a lower ride height, which I highly recommend. I may eventually play with sway bars, but have been pretty pleased with the performance of the stock setup. Stock brakes (GS calipers, fresh fluid and vented rotors) and cooling seem adequate thus far, although on a longer race or with stickier tires that might change. One other thing I want to look into is potential weight savings. Not sure if that helps, but I'll keep this thread updated with my findings. Last edited by jrtoffroad; 04-18-2011 at 12:13 PM. |
#10 |
![]() Join Date: May 2008
Jordan, it sounds like you're hooked! I have only autocrossed my '92 ZR-1 on two ocassions. Once at the National Corvette Museum and at my local club's event, here in Michigan.
I have also run my stock C5 coupe, with Z51 suspension and C6 Z06, which is also stock. You are headed in the right direction, by making alignment adjustments, tire pressure checks and searching for the right tire. All of that is very important, but if I may offer some advice, you may want to look at a dedicated tire if you get real serious. If you continue to use your street tire, you will consistently find yourself 2-3 seconds slower than the guy with a race tire. If you don't compare yourself to others, then use the street tire and keep having fun, just improving YOUR times and skills. "Seat Time" more than anything else will help you be a better autocrosser, and you seem to be on your way. Congratulations and be safe in experiencing your Corvette!
Joe Thomas Corvette Club of Michigan NCRS-Michigan Chapter Member NCM Master Ambassador NCM Lifetime Member Former NCM Board Member 1991 ZR-1 Melon Copper Metallic/Black 1992 ZR-1 Bright Red/Black (Sold) 1995 ZR-1 Bright Aqua/Gray (Sold) 2012 ZR1 Super Sonic Blue / Dark Titanium |
